Polk Fxia6 Surround speaker maximum wire length . . .
SolidSqual
I will be permanently installing my new Fxia6 surrounds here in the next few days. I got the Tapcons installed and the speakers are receiving plenty of support on my wall. But, am wondering whether I can run a 30 to 45 foot speaker cable without any issues? I am using the Blue Jeans top line Belden speaker cable 12 gauge. My receiver is a Pioneer SC-27.
The variation in cable length is contingent on whether I can run the cables through the walls at 45 feet or am forced to run under the carpets via a more direct route at 30 feet.
Thanks for you input,
Mike
Mike
Post edited by SolidSqual on
Don't see why not. 12 guage is plenty big enough for a 45 foot run. I have 30 ft 16 guage wires running to my surrounds without any problems.
I'm running 35 ft to my sides and 70 to my rears. Doesn't seem to be an issue.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
The 12 gauge wire should be fine with a run of 30-45 feet. You could probably even double that and not have any issues. I thought that 12 gauge was good for runs up to 100 ft.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Awesome, thanks guys.
SolidSqual,
Been trying to get input on FXiA6 speakers regarding my 37x15 room. What are your room dimensions. How do they sound. -
About 15W X 18L X 15H. I have no complaints thus far. The speakers add great effects to all my movies and games and never sound strained. You would probably do well to have a surround and back pair of FXi6 speakers in your room. I think I probably would have been fine with the Fxia4 speakers in my given setup, but I like the added power of the 6s.
