Direct Or EQ'd
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited January 2010 in Electronics
Just wondering if people like listening to music that has gone threw a internal or external EQ or going direct. I like both depending on the music and how loud it is. :p
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    Assuming you are referring to an AVR, when I used to listen to music through my AVR I found I liked Direct best.
  • bigaudiofanatic
    edited January 2010
    I am referring to both internal and external EQ, but yes threw my receiver I like direct more and more now.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2010
    I actually like the effect that Audyssey's equalization has on my music, especially with DynamicEQ engaged at the 10dB offset setting.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    tonyb Posts: 33,069
    edited January 2010
    I play all my music in direct analog, let the player do the converting. Not a big fan of all that processing, keep the signal as pure as possible.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    I like Audyssey for HT but I use Direct mode for music. Having said that, I rarely listen to music through my AVR. Music DVD's and concert DVD's etc. I use Direct mode.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2010
    I've been thinking of hooking up a nice used 15 band per channel stereo graphic equalizer between the preamp and power amp and use it only for 2 channel playback. Used to use one in the tape monitor loop back in the pre AVR days.
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Direct. No changes, period. It's a cardinal sin. ;)
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2010
    Direct, always.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • doctor r
    doctor r Posts: 837
    edited January 2010
    Don't mess with the signal! - Direct
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • joeparaski
    joeparaski Posts: 1,865
    edited January 2010
    I use the eq to tailor the sound to the way I like it. There's no such thing as "pure direct" unless the artist is playing his guitar "live" in front of you in your living room. The "sound" engineers already altered the signal before it even got onto the cd. IMHO of course.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • louhamilton
    louhamilton Posts: 209
    edited January 2010
    Direct here, as well.
