Direct Or EQ'd
bigaudiofanatic
Just wondering if people like listening to music that has gone threw a internal or external EQ or going direct. I like both depending on the music and how loud it is.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
Assuming you are referring to an AVR, when I used to listen to music through my AVR I found I liked Direct best.Speakers: SDA-1C (most all the goodies)
I am referring to both internal and external EQ, but yes threw my receiver I like direct more and more now.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I actually like the effect that Audyssey's equalization has on my music, especially with DynamicEQ engaged at the 10dB offset setting.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I play all my music in direct analog, let the player do the converting. Not a big fan of all that processing, keep the signal as pure as possible.HT SYSTEM-
lsi 9's -
I like Audyssey for HT but I use Direct mode for music. Having said that, I rarely listen to music through my AVR. Music DVD's and concert DVD's etc. I use Direct mode.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I've been thinking of hooking up a nice used 15 band per channel stereo graphic equalizer between the preamp and power amp and use it only for 2 channel playback. Used to use one in the tape monitor loop back in the pre AVR days.
Direct. No changes, period. It's a cardinal sin.
Direct, always.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Don't mess with the signal! - Directintegrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I use the eq to tailor the sound to the way I like it. There's no such thing as "pure direct" unless the artist is playing his guitar "live" in front of you in your living room. The "sound" engineers already altered the signal before it even got onto the cd. IMHO of course.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Direct here, as well.
