blown speakers
jukeboxhero
I posted a thread earlier this morning about a pair of rt20P's that one of the towers subs (mw8003) and the mid-range(mw7009) are gone. The other tower sounds wonderful. My question is, "Can anyone tell me what way I should go about fixing the problem"? Would it be cheaper to send them into Polk or buy somewhere else? I picked these up yesterday for $40.00. I'm also a greenhorn to the forum so bear with me. Thanks. I also own a pair of sda-2b's that are the bees kneez and a pair of Monitor 4's. I'm pushing them with a Pioneer elite A-88x.
Post edited by jukeboxhero on
jukeboxhero wrote: »I posted a thread earlier this morning about a pair of rt20P's that one of the towers subs (mw8003) and the mid-range(mw7009) are gone. The other tower sounds wonderful. My question is, "Can anyone tell me what way I should go about fixing the problem"? Would it be cheaper to send them into Polk or buy somewhere else? I picked these up yesterday for $40.00. I'm also a greenhorn to the forum so bear with me. Thanks. I also own a pair of sda-2b's that are the bees kneez and a pair of Monitor 4's. I'm pushing them with a Pioneer elite A-88x.
problem could be the xo, I'd pull it out and check.
welcome to club polk!
jrpanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Thanks for the reply. I'll research that!
anytime. check out this thread, might help in finding your problem
http://www.polkaudio.com/forums/showthread.php?t=93536
good luck
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
