SDA -1's on Ebay
fafner
fafner Posts: 115
edited January 2010 in Vintage Speakers
These speakers are barely within my price range and driving distance.
Any opinions on getting these or waiting for a set of SRS's?
http://cgi.ebay.com/POLK-SDA-1-Speakers-Pair-Sound-great_W0QQitemZ300373101937QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item45efa1cd71
fafner
Fronts - Polk SDA2B's
Center - Polk 350CS
Surrounds #A - Another pair of SDA2B's
Surrounds #B - Another pair of SDA2B's
Rears - Yet another pair of SDA2B's
Subwoofers - 2 M&K's
AVR - Denon 3808CI
Display - Sony 52KDL4100
Blu-ray Player - JVC BP-1
HTPC - Self built - Intel Quad Core I7 920@4.0ghz
Post edited by fafner on
  • Pycroft
    Pycroft Posts: 1,961
    edited January 2010
    Those are some FINE speakers. Whether they are what you want, or worth it to you is a personal decision.
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2010
    SDA 1B's are in my opinion underrated. They are actually very good.
    With the exception of a couple of pushed dust caps they seem to be in pretty good condition. Price is a little on the high side, so if your plan is to trade them for a bigger one later, I would just wait for that next one.
    SOPA
  • BuckeyeTim
    BuckeyeTim Posts: 483
    edited January 2010
    Those have been on Ebay for at least a couple months now. I am assuming the reason they are still there is the price. I have considered them a few times, but am still hoping for the set that has only been driven around the block once or twice and then retired to the closet.
  • dpowell
    dpowell Posts: 3,081
    edited January 2010
    Those are 1C's. They only have a single speaker binding post. Paid $450 for my studios (without the wood paneling) in mint condition and VERY happy. The price seems within reason if they are functionally and cosmetically in good shape.
  • StevieB
    StevieB Posts: 257
    edited January 2010
    I think the 1c studios have the black cabinets. Look like 1b's.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2010
    Hmmm. My 1C's have black cloth side panels and wodden caps.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dpowell
    edited January 2010
    Maybe my manual is wrong. The original manual came with the 1C's I bought. It has the primary manual which came with a 'B' series and an addendum that Polk included for the 'C' version. One of the distinctions between the B's and C's according to the manual is that the B's have dual binding posts where the C's don't. I'd love to get this one cleared up by someone in the know....
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2010
    My 1C's are studio 1Cs and are piano black and single binding posts - and 6 Ohms impedance
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • Fongolio
    edited January 2010
    I meant wooden end caps in my post a few posts back. My 1C's like all 1C's have single binding posts.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
    heiney9 Posts: 25,443
    edited January 2010
    1C Studio's were black and had the base.
    1C Regular had the cloth side panels and the wood/wood veneer end caps.
    all 1C's had single binding posts.
    1C's had blade/pin, except some very early 1C's had blade/blade and could not use the AI-1 w/o internal modification which you would need to contact Polk about.
    The 1's in question here look like 1B's or at best very early (change-over model-blade/blade) 1C's. The way to tell for sure is to pull the drivers and see which model #'s they are. 1C's used the newer edge-wound voice coil drivers similar to what the SRS's were using at that time. I have 1C's and I can't remember the driver #'s off the top of my head MW6510 & MW6511 I think (my SDA compendium is at home).
  • smglbrth
    smglbrth Posts: 1,496
    edited January 2010
    According to Polks literature of the time period they are 1B's. They have the kick plate at the bottom and look exactly like the pics in the literature I have.
    1B's are a 4 Ohm speaker, 14Hz-26,000Hz, maximum output level of 122dB and an efficiency of 92dB.
    Would probably take a good amount of juice to make them run well.
    My .02 ....
