To Use or Not to Use Interconnect Cable With SDA 2A;s?
fafner
As I mentioned in my introductory post I am using SDA 2A's as my mains and surrounds. I also have a high end Yamaha center that sits under my LCD.
I am not using the interconnect cables since I have a center and am using the second pair as surrounds.
Is this correct or not?
Thanks.
fafner
Thanks.
fafner
Fronts - Polk SDA2B's
Center - Polk 350CS
Surrounds #A - Another pair of SDA2B's
Surrounds #B - Another pair of SDA2B's
Rears - Yet another pair of SDA2B's
Subwoofers - 2 M&K's
AVR - Denon 3808CI
Display - Sony 52KDL4100
Blu-ray Player - JVC BP-1
HTPC - Self built - Intel Quad Core I7 920@4.0ghz
Center - Polk 350CS
AVR - Denon 3808CI
Post edited by fafner on
It is my understanding that you are not hearing the full potential of the SDA's imaging without the umbilical cord. I'm sure others, more experience than I, will chime in. I only have experience with the SDA CRS and have only heard them with the cable. I used them for the mains on my HT and they sounded great with a pair of RT800i towers in the rear, a CS400i center and a PSW450 sub. Because of lack of space, I could not position the CRS as Polk suggested, and have removed them from my system (see signature).Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
An interesting question. Since I'm exclusively 2-channel it's not come up for me, but the SDA effect is specifically designed for 2-channel. Placement, alignment, listener position all affect it, and under the assumption of only 2 speakers.
Injecting more signals into the room "airspace" from additional speakers at different locations/directions would seem destined to interfere with the optimal SDA effect you get with a 2-channel system.
But I'm just guessin' and will be interested to see replies from those that have actually tried it. -
The biggest affect on the SDA effect (that I can think of) is the fact that you are running 5 discrete channels rather than a normal stereo signal. Exactly what affect this has on the SDA signal I do not entirely know. Maybe someone with more exprerience can say more about this.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Use the cable or just sell the speakers and get new ones."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Let's just wait a minute here. It doesn't matter how many channels you are hooking up, if you want the most out of the sdas' you use the interconnect. If you are only listening to two channel music you hit stereo button on the receiver and listen to stereo. You do notwant to listen to music any other way unless its dvd concerts.
Hopefully this info helps you out.
JoeJoe -
I've done it each way--Stereo and HT; with and without the SDA interconnect.
There's nothing "wrong" with pulling the interconnect and losing the SDA effect. You go back to "ordinary" stereo from that pair of speakers. It's pretty similar to listening to any other decent pair of speakers as the main Left and Right pair; and it's no different from listening to other "full-range" or "Big" speakers as the main L and R pair of a multichannel system.
But either way--Stereo or Multichannel--they're "better" with the SDA effect functioning properly. Having a bunch of other channels also providing directional cues does not change the value of having the SDA effect.
While I haven't tried it, I'd think that having rear surround speakers set up with the SDA functioning would be a similar benefit; although with movies there isn't all that much signal present; and multichannel music (DVD-A and SACD) is still 5.1 (unless re-processed, right???) The side surround speakers would be another story--no SDA effect possible due to the position of your ears relative to the speakers. -
I'm using the cable for both my fronts and surrounds. I've tried it without the cable. It still sounds great, but with the cable 5.1 is more like 7.1. I'd say, give it a try. You've got nothing to lose if you don't like it.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
fafner, personally I would always use the interconnect cable on SDA's. My side surrounds, which are RTA-15TL's, are obviously the only ones that do not use it in my 7.2 setup.
Point Being.....Use The Interconnect Cable, Period.
----BILL(BB3)Sony 52in.XBR6
Sony 32in.XBR6
Anthem AVM50V
Anthem PRE-2L
Sonic Frontiers SFCD-1
Carver C-9
Carver C-19 PreAmp
Carver C-16 PreAmp
2-Carver Silver 7-T's
4-Carver TFM55's
2-Carver TFM35's
1-Carver TFM25
Carver 490T
Denon DCD1560
Sony BDP-S350
Sony PS3
Nintendo Wii
Panasonic DMK23DVR
Speakers :
PolkAudio SDA-SRS
PolkAudio SDA-SRS 1.2TL
PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
PolkAudio RTA-15TL
PolkAudio M3
3-Velodyne F-1500's -
Actually it not as simple as just listening to "ordinary" stereo. Anyone can do whatever they want with their own speakers, but removing the chord doesn't make them just an ordinary 2-ch set of speakers. The dimensional array only plays certain frequencies when hooked up, and when not hooked up in the older models they don't play at all and in newer models you are missing a lot of the signal.
If you have 1st or 2nd gen models pulling the plug means dead dimensional drivers. 2B's, 1B's, 1C's, SRS 1.2, 2.3 and all TL models will have the dim drivers play but at a diminished level and only certain frequencies when you pull the plug. That's not "ordinary" stereo as I know it. I early side by side tweeter models you loose the outer tweeter as well when you pull the plug.
That's why I said if the OP isn;t going to use the cable he might as well just get a regualr pair of newer HT speakers to run with his 7.1 rig.
Well, I did suspect this would be somewhat of a controversial question and hope it was not out of line.
My reasoning for not using the cable was my perception that the SDA effect was a way to "simulate" a center and surround channels at a time when such setups were not a real option. With a setup actually having speakers for those channels, I felt trying to "simulate" them would simply overlay the actual ones and cause a muddy mess.
I respect everyone's opinions here, and will reconnect the cable to my fronts. It will not be so easy to do with my surrounds because of how far they are apart but I might be able to somehow finagle it.
With no one saying my concern about mudding the sound is valid, I see no reason not to use the cable.
Thanks for everyones' opinions.
fafnerFronts - Polk SDA2B's
Center - Polk 350CS
AVR - Denon 3808CI
HTPC - Self built - Intel Quad Core I7 920@4.0ghz -
As many people have said, it's better to use it than not to. I have my 2Bs set up for home theatre for the fronts and am using the SDA cable for them. It would be silly to not to and still own/use the SDAs. As I stated before though, I am not too sure how much SDA affect you actually get when using them with discrete 5.1 channels though. No one has said anything about this still? Anyone know something about it? That is, using a discrete 5.1 channel signal instead of a normal stereo signal and the effect on the SDA signal?
I would be interested to know.
With the cable in use, try deleting the center speaker from the mix. You might perceive that it's still there !!;)
fafner
SDA's are not about "simulating a center channel" any good speaker worth its salt will create a phantom center as long as the recording allows it. Many Beatles recordings have distinct vocals in the L or R channel so even on SDA's they don;t appear in the center. (because they weren;t recorded that way).
It's alright to discuss, and yes you will get some strong opinions. SDA's can be used as HT speakers resonably well, but they are designed and best utilized in a 2ch rig with the cable intact."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Guys,, what Brock just said--of particular interest is his statement regarding the Beatles recordings,, a very good/important observation that had me puzzled for a couple of months.Now to dig out that old Mamas' and Papas LP that I thought was out of phase.JC approves....he told me so. (F-1 nut) -
I did an experiment. I had already planed to watch an opera DVD this afternoon, so I playerd 30 minutes of it without the cable so I could get a feel of the overall sound of the DVD. I paused playing during a male chorus and plugged in the cable. The first thing I noticed was sound from the center was noticeably lower. After I corrected for that, I noticed that I was no longer hearing a male chorus but a collection of male voices. There was empty space around each voice and they were clearly positioned at difference places across the stage. I then noticed the same kind of separation between different instruments in the orchestra and finally, I heard sound above the speakers, adding more to the spatial effects that the cable enabled.
Thanks for the comments. It usually pays to ask and listen to experts
Center - Polk 350CS
AVR - Denon 3808CI
That is the beauty of SDA. Long live SDA.Political Correctness'.........defined
President of Club Polk -
I've got 1 redbook CD that has crosstalk cancellation in the recording that I must disconnect the cable for. Everything else sounds neutered.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
fafner
Yep SDAs do that. I love their presentation. As Jesse said, "Long live SDAs." -
Thanks.
fafner
Welcome to Club Polk!
Not to beat a dead horse, but personally, I would use the cable 100% of the time.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
