RTi4??????
VR3
VR3 Posts: 29,534
edited October 2003 in Speakers
video-shielded
bass-reflex
frequency response 80-22,000 Hz (-3dB)
8-ohm impedance
sensitivity 88 dB
handles up to 100 watts
dual 5-way binding post terminals
keyhole slot for wall-mounting
real wood veneer
7"W x 12"H x 11-1/2"D
warranty: 5 years
Priced per pair
WHAT IS GOING ON??????????????????????
22khz???????????????? That is lower than any of the speakers in the line!!!
80hz????????????????? Is Polk going Infinity on me?? Thats 20hz less than the RT25i!!! -3db, which is what Crutchfield normally does. Smaller cabinet, less effeciency.......
I'm just not seeing this......
Seems they sacrificed alot to get them dual binding post on that speaker. Hopefully this thing sounds better than what the specs are making it out to be. The RT25i was awesome, and the specs murdered this. Hopefully this is one of them moments when specs mean squat. I just don't understand.......
22KHZ??????????? When the rest of the line is.......26khz???
Post edited by VR3 on
    VR3 Posts: 29,534
    edited October 2003
    Note
    Frequency Response Note: The overall frequency response is 50Hz-27kHz and the -3dB frequency response is 60-26kHz
    DANGIT CRUTCHFIELD!!!!!!!!!! CHANGE THE SUMMARY SPECS!!!!!!!! That is more like it.....
  • gatemplin
    gatemplin Posts: 1,595
    edited October 2003
    You cant hear higher than 20 KHz, why do you care?
    Graham
    VR3 Posts: 29,534
    edited October 2003
    Sounds fuller..... ;)
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2003
    Actually it's more likely to just sound more irritating...
    More later,
    Tour...
    Vox Copuli
  • TroyD
    TroyD Posts: 13,124
    edited October 2003
    If I'm not mistaken, CD's are only recorded to 20kHz (and Sid, the 22kHz is the upper end of the spectrum) and you can't (unless you got the ears of a bat) hear that high anyway.
    The DQ-10 has a piezo super tweet that goes out flat to something like 40kHz or some such. It's crossed over at like 17 or 18kHz. Many folks just unhook 'em and can't even tell.
    BDT
