Spray-on/roll-on bedliner
concealer404
concealer404 Posts: 7,440
edited January 2010 in The Clubhouse
Anyone have any experience with this stuff in a DIY situation?
I'm needing to use this stuff for a project, and i'm looking for cheap and durable. Aerosol can, roll it on, or use a compressor, whatever. I'm going to need enough of it to do about the equivalent of four 8ft truck beds i imagine, and i'm looking to do it as cheap as possible.
Any recommendations are welcome! :) Thanks!
Post edited by concealer404 on
  • Fireman32
    Fireman32 Posts: 4,845
    edited January 2010
    When I had my Ranger I used a DIY kit and it worked out quite well. I forgot what brand it was. The main thing is the prep. Making sure the bed is clean and then scuffed really well so it will adhere when you roll it on. I did 2 coats and it came out very nice.
  • concealer404
    edited January 2010
    How runny is this stuff? It's not going on a truck bed, and i'm hoping to avoid random lumps, and runs, which is my only potential issue with the roll on method.
  • Fireman32
    edited January 2010
    what I used was pretty think. What are you putting this on?
  • concealer404
    edited January 2010
    Fireman32 wrote: »
    A car. :p
  • Fireman32
    edited January 2010
    Well ok then. As long as your carefull you should be ok. I would suggest the roll on
  • domflane
    domflane Posts: 653
    edited January 2010
    Look for Herculiner, it comes in gallons and rolls on. I like it, it coats really well and is fairly cheap. I used it on utilities work truck beds and on the shelves inside the tool box and had no complaints. Very tough stuff and much cheaper than a $600 Line-x.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • unc2701
    unc2701 Posts: 3,587
    edited January 2010
    Agreed- it comes out really thick and sticks well. I used it on some MDF speakers and a DIY turntable platform, roll on. Works great, but make sure you've got PLENTY of ventilation. I had the garage door open & a fan running and still killed more brain cells than a two week bender.
    Think I have the remains of a can in the garage- will check the brand tonight.
    Backburner:Krell KAV-300i
  • concealer404
    edited January 2010
    Can you "thin" this stuff at all? I'm trying to avoid adding like 100lbs of weight to the car. I'm really just looking to cover up the god awful paint that's on the car right now in the easiest way possible without resorting to rattle-bombing the whole thing flat black, and REALLY don't have the motivation to spend the time on this car to actually paint it in the "correct" way.
  • unc2701
    edited January 2010
    Dunno about thinning, but as a whole, this is probably a bad idea. Herculiner runs about $80-$90 a gallon. For the amount you'd need, you might as well get a cheap Maaco paint job.
    Now, if you really want is a badass bedliner-car, then go for it. If you want to save some money with a DIY, it's not a good choice.
  • Fireman32
    edited January 2010
    I agree I would not paint a car with this stuff.
    nooshinjohn Posts: 25,877
    edited January 2010
    make sure to cover the rust holes with duct tape first.:D
  • concealer404
    edited January 2010
    unc2701 wrote: »
    I've been finding roll on kits for around $40 for a gallon, i'm pretty sure i could do the car for under $200 including the small tub of bondo i would need to take out a couple dings.
    I guess my problem is that i don't trust Maaco's prep, and i don't have enough motivation to properly prep a $900 car to the point that it would need.
    I appreciate the info thus far, though, it's certainly given me some info and other things to think about. :D
  • concealer404
    edited January 2010
    I lucked out on this one John. No rust!!!!! :D
  • shawn474
    shawn474 Posts: 3,052
    edited January 2010
    I have seen a couple of guys that off road with their trucks do this. It does add a LOT of weight to the trucks. Overall, it looked really cool and was functional as hell for what they were doing. I have a daily driver pick-up; otherwise I would do this if it needed painted. The prep, as stated, is essential to it lasting a long time. It comes in different colors as well.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2010
    Does this type of coating work good on black plastics, such as ATV body panels and such?
  • unc2701
    edited January 2010
    Probably depends on the precise type of plastic. It's definitely got some serious solvents in there, so I could see it penetrating some plastics for a _VERY_ permanent bond. Regardless, you'd want to scuff the surface to get a good bond.
