ABC Monday Night Football
HBombToo
HBombToo Posts: 5,256
HDTV
I noticed that at the beginning of the game I was 16:9 then a storm rolled through. Reception sucked bad for a monent then no audio then 4:3. Been that way all second half,... and I'm curious if you saw the same thing?
I'm wodering if it was a national problem vrs a local 1. The image really is awsome on HD and worth an upgrade. I'm no vidiophile but I will have my set adjusted.
Twin
***WAREMTAE***
