Rosewood Studiotech DP-2 with plasma mount
gelinas
gelinas Posts: 226
edited January 2010 in For Sale (FS) Classifieds
Hello,
Up for sale is my studiotech DP-2. It is in the rosewood color. I am the original owner and have had the stand for 10 months. I will include the stand, dp-pmp risers, and wall mount bracket (required to attach plasma to dp-pmp risers). I paid $499 for the stand, $89 for the risers, and I believe $60 for the plasma mount--it came to $650.
Some specs:
Height 19.5"
Width 47"
Depth 22.75"
Shipping Weight 105 lbs
Max. weight (total) 300 lbs
Max. weight (top shelf) 250 lbs
Number of casters 4
Shelf spacing (bottom to top) 8" / 6"
The height you can mount the plasma is almost infinitely variable allowing for center channel's of a wide variety of heights. The risers can support up to 150 lbs. This stand is great for people with tall center channels who do not want to wall mount their plasma.
It is in like new condition and I would be willing to deliver a reasonable distance from Maryland zip code 21043. I have a truck so I would be delivering the fully assembled stand. I would also welcome you to come pick it up at my home.
I'd like to get $500 for the set of 3 items (if you come pick them up from my home). If you live reasonably close, get in touch with me and maybe we arrange for me to deliver this set-up to you.
Audioholics gave it a quite favorable review:
http://www.audioholics.com/reviews/furniture/racks-stands/studiotech-dp-2-flat-panel-tv-stand-review
Here's a link to the Studiotech page (you can see the dp-pmp risers listed at the bottom):
http://www.studiotech.com/products/plasma_tv_stands/dp-2/index.html
And here's some pictures. For size reference the plasma in the picture is 42" and the center channel is the csi3 (I have since upgraded to the BIG csi a6 without issue.)
Here's a side shot showing how the risers attach. They actually go through the top and bottom wood shelves and are very sturdy.
When you adjust the height of the risers correctly you can make them disappear behind your center channel from your seated view
Post edited by gelinas on
