How much do the floor spikes add to the width?
Specifically on the Monitor series (50 or 60). The cabs are 7" wide per the Polk website. I have a very narrow space to work with. How far beyond the cabinet sides to the spikes extend?
Post edited by lmacmil on
Don't know off the top of my head, I have the 70's and I would guestimate maybe an inch or so max. I have heard they are removable, but I looked at mine and didn't see a way to di, but I didn't really try that hard to figure it out, lol.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Floor spikes typically don't stick out at all. They are usually tucked in under the corners.
I have the Monitor 50's and already had a sketch for my layout.
The feet stick out 1" beyond the cabinet on each side.
They do not stick out beyond the front or back.
Hope that helps.. -
hearingimpared wrote: »Floor spikes typically don't stick out at all. They are usually tucked in under the corners.
That's true, but on the Monitor series, they do.I have the Monitor 50's and already had a sketch for my layout.
Hope that helps..
Awesom post/sketch!! I was close, didn't realize it was that much.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Hope that helps..
Exactly what I needed, thanks!
wutadumsn23 wrote: »That's true, but on the Monitor series, they do.
Thanks Bro, in my best Johny Carson voice, "I . . . did not know that!":)
