Lsfx suggestion??
I´m able to get a pair of LSfx for 100 USD. Apparently they´re in good condition. I will audition them before buying. Assuming they´re fine, is this price ok, or is it too much??
I will use them as surrounds. I´m not sure if I´ll replace my TSi100, or going to 7.1. My system is TSi300 as fronts, TSi100 for rears, and CS10 as center. I know there is a lot of discussion about 5.1 vs 7.1, my space is a bit small right now but plan to move to a bigger, dedicated area. Anyway, either for 5.1 or 7.1, do you think they will work nicely with my setup? It is being powered by a Denon AVR 790
Many thans
Many thans
Post edited by dfledezma on
I paid $100 for some recently here on the forum but that was shipped. I'd see if you could get them a little cheaper. That being said, being somewhat vintage they are not a very good match for your current set-up. You might be OK for surround duty but I'd suggest trying to stay within the same line as your current gear.
Just my .02
