always wondered about this!
wrigley
Is there a noticeable difference in volume db's/tone if you manually turn your volume know to a setting and then adjust the volume from there with a remote vice manually turning the volume all the way down/off and soley using the remote to control the volume?
Mike
Mike
Post edited by wrigley on
If i understood the question, no.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
+ 1 to not really understanding the question, but no, the volume is the same if you use the knob or the remote.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
