What is missing in my step up?
hitz
hitz Posts: 4
Hello everybody,
I am new to this community and to the Polk Audio world. I would greatly appreciate if I can get your expert opinion and/or suggestion.
Little History:
I used to have a crappy 5.1 channel speakers sourcing from Sony STR DE598 (6.1 channel receiver; 90watt/channel). Issue: while watching DVD’s & BluRay, I constantly had to increase volume to hear vocal and decrease volume during action scene.
A year ago, I replaced the stock center channel with Polk Audio CSM center speaker. Things got better but not a whole lot… I was still juggling with volume to decrease during action scene.
Present:
I have Monitor 70 for front, CSM for center, Monitor 40 for surround and Subwoofer PSW 110 (little brother of PSW125). Things got considerably better. However, I am still fighting the eternal battle of volume control when watching movies…. I still have to crank up the volume to hear the vocal and decrease the volume when any action kicks off.
Speakers are hooked up with 16AWG wire using banana plugs and my setup is configured for 5.1 surround. My use is 50% movies and 50% Music.
What is missing in my step up? Center speaker, Receiver, both, or nothing?
While playing music, system sounds awesome and receiver is producing enough juice as there seems to be no issue with CSM (center speaker) and everything blends in perfect.
The issue is when vocals kick in while watching movies, show, games, etc.
Any help is appreciated.
Thanks,
Hitesh
CSM specs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290125
Sony STR DE 598 specs:
http://www.amazon.com/Sony-STR-DE598-Channel-Surround-Receiver/dp/B0007Y6AN0
Post edited by hitz on
  • Conradicles
    Conradicles Posts: 6,339
    edited January 2010
    Welcome to Club Polk Hitesh!
    By no means am I an expert, but I had a Sony receiver like that one (I think it was very close in model #). I replaced it and was amazed at how much better my system sounded.
    You should think about selling that Sony and buying a new AVR.
    Others will chime in with more advice, but I think it is safe to say that is the weak link in your system.
    Have a great evening,
    Eric.
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Doesn't that center actually go with the R-series?
  • sandworms
    sandworms Posts: 1,043
    edited January 2010
    if your sony has adjustable level control for all channels you can try bumping the center ch a few db's. i had that problem for quite some time untill i got a decent center and a pre-amp with audessy mult eq
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    +1, I would agree that a new center should be on the top of your list. Timbre matching is very important with your front 3 and the center, IMHO, is the most important of all in any HT setup. Something like 50-75% of all audio is formatted to be played by your center, esp. dialogue. Do your self a favor and get a CS2 from Newegg, they are $119.99 w/ fre shipping and available in black and cherry. The CS2 is a beast and I think you will notice a difference with it if you were to get your hands on one. Just be careful though, placement can be an issue due to it's size, so take a look at the specs before you buy it and make sure you can accomodate it. Volume control will be less of an issue with the CS2, and I think the reason why you have that issue now, is because of the mismatched center. Your AVR could also be a downfall, it is an older one and doesn't have HDMI or pre-outs for adding an external amp down the road. You may not need an amp now, but you will eventually end up there if you stick around here long enough, lol. I don't know if you have a need for it or not, but if you plan to go Blu-Ray you will need it to be able to enjoy them to their full potential. Maybe even a sub is in your future as well, I have the 125 and I find it works very well in my small room, but bass can be an issue if you have a sizeable room and only the 110 trying it's heart out to fill up the room. Give us a budget and where you would like to end up in the future. Welcome to Club Polk, hope this helps.
    -Jeff
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290024&cm_re=polk_audio_cs2-_-82-290-024-_-Product link to the CS2 on Newegg
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited January 2010
    I once owned that receiver...and ran it with some cheapo Sony speakers...I gave it to my son with a HTIB speaker system for his new apartment years ago. And set it up for him.
    Your main problem is your center...get a CS2 and even with a Sony things will sound much better as Jeff says above. That's not a horrible AVR it just doesn't have much power. So I also wouldn't run it in more than 5.1 even though it is 6.1 capable. The MENUS though, are a bit screwy.
    cnh
    tonyb Posts: 33,072
    edited January 2010
    Bump up the center volume manually in the blu-ray player. Do it also in the receiver and make sure your speaker wire is connected properly.
  • wutadumsn23
    edited January 2010
    tonyb wrote: »
    LOL Tony. You are right we are starting to sound like broken records. Oh well, I don't mind helping, you guys put up with me when I was new. Hell you still put up with me now, lol. :D
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    tonyb Posts: 33,072
    edited January 2010
    I think his problem is in his set up menu on the blu-ray. On most, if the channel level is set to "fixed", all levels for all speakers are automatically set to their max. You have to change the channel level to "variable" to adjust the individual speaker levels.
  • hitz
    hitz Posts: 4
    edited January 2010
    Thank you everyone for suggestions.
    CS2 seems to be huge; I will check to see if it will fit in the space (CSM is also big). BTW, when I bought Monitor 70 and 40, this was my wife's statement:"If I see anymore speaker come in, you are going out". My WAF has been very low lately.
    I use PS3 for DVD's and Blu-ray. I don't think there are any settings on PS3 for speakers channel level/volume; however, I will check it again.
    On receiver, settings for surround and center channel is from -10 to +10db and I have set them to +5db for both, surround and center. Do I need to increase or decrease these settings?
    My budget is exhausted for now.:( I can only stretch it for CS2. I don’t foresee a new AVR or an amp.
    Thanks,
    -Hitesh
  • concealer404
    edited January 2010
    Solution: Buy the CS2. Hide it until she's gone for a little bit. Hide the CSM. Sell the CSM.
    If she says anything "That one looks different, is it?" Tell her she's crazy.
  • wutadumsn23
    edited January 2010
    LOL, she'll never notice, lol. There are no tweaks available on the PS3, that is all done through your AVR, keep messing with it until you get it working right. The CS2 will solve most of your problems, IMHO.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    edited January 2010
    Sounds like a plan you've used in the past..well, I think I've done the same thing once or twice myself..if we're telling the truth. Wives rarely understand 'upgrrades'...but I did get mine to admit that if I SELL something I would be 'allowed' an upgrade.....so we're half way there...ha, ha!
    cnh
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    lmao! thats pretty much how I smuggled my whole system in place :D
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • concealer404
    edited January 2010
    cnh wrote: »
    cnh
    Nah, i just tell the girlfriend i'm buying something. If bills are paid, she can't say anything.
  • hitz
    hitz Posts: 4
    edited January 2010
    thanks for wonderful ideas and suggestions.
    I am going with concealer404's way. I ordered CS2 from newegg.com and planning to make a switch over the weekend as my wife is going out for a shopping with her girlfriend.
    can't wait anymore...
  • wutadumsn23
    edited January 2010
    Good plan, that CS2 is going to make all the fifference in the world, IMHO. Let us know how it works out, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • concealer404
    edited January 2010
    hitz wrote: »
    Nice! Keep us posted on how that all goes. ;) Also of course, how you like it. :D
  • hitz
    hitz Posts: 4
    edited January 2010
    Made the switch over the weekend and the best part....wife didn't notice the switch...... upgrade to CS2 from CSM is worth it...... The whole system came to life. Unbelievable............. Polk rocks.
    Thanks everyone for your input and suggestions.
    Hitz
  • wutadumsn23
    edited January 2010
    No problem, glad you were able to make the swap. That CS2 is a beast, and I knew it would make a world of difference for you. Congrats!!
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • jchjchjch2
    jchjchjch2 Posts: 14
    edited January 2010
    Awesome. That's almost exactly what I did with my new Rti towers. The only difference is that she knew she wasn't crazy, just a little unobservant.
    I think buying the CS2 is a great idea, but here our my thoughts about that Sony....
    I had the Sony 698, which is very similar to your current AVR. I was running two Rti4s for fronts, CSi3 for center, and a PSW for bass. Because all these speakers were in the Rti series they were voice-matched (don't know if that's the correct term?).
    To say the least, I had similar difficulties with dialogue coming out of my center speaker. Turning the center speaker up, in comparison to the fronts, helped but seemed a little too bright and unnatural. I noticed a huge difference when playing DVDs that had DTS -- my system sounded the way it should sound.
    I've since sold that receiver and have gone on to Harmon Kardon and now Onyko. Audessey on Onyko really calibrated my system well. Dialogue can be heard without turning the volume up and being blown out of your chair and waking up your neighbors when a action scene surprises you. Right now, I think what's effecting your dialogue is the AVR and current sound format of those DVDs. With this being said, I hope you find a solution with that new center speaker.
    Onyko TX-SR607
    Polk CSi3
    Polk Rti8s
    Polk Rti4s
    PSW303
    Samsung BD-P3600
    Sony RCD-W500C
    Audio Quest 14AWG
    Audio Quest HDMIs
  • jchjchjch2
    edited January 2010
    Sweet. I somehow missed your last post. Good for you!
    Onyko TX-SR607
    Polk CSi3
    Polk Rti8s
    Polk Rti4s
    PSW303
    Samsung BD-P3600
    Sony RCD-W500C
    Audio Quest 14AWG
    Audio Quest HDMIs
