Toslink to RCA (digital to analog) adapter needed
apc
apc Posts: 779
edited January 2010 in Electronics
My in-laws have a Vizio tv. We got them TV Ears for a present, but cannot hookup because the only audio output the Vizio has is toslink digital. I need to convert the toslink to an analog RCA jack to input to the hearing device.
I know there are expensive converters, but they cost more than the hearing device. Anyone know of a cheaper way to convert for this purpose, say $20 or less?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Going to have to use a converter. Toslink is optical (light) and can't simply be adapted. Is there no available analog output? A headphone jack maybe?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • apc
    apc Posts: 779
    edited January 2010
    Believe it or not, nope.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Crazy.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • apc
    apc Posts: 779
    edited January 2010
    Yes. Should be much easier than this!
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited January 2010
    This should work you may need a 3.5mm to RCA adapter, and a USB power adapter:
    http://www.meritline.com/usb-sound-adapter-789---p-35243.aspx?source=fghda
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    William, I'm not sure that will work, as it is a USB sound card and I would imagine that the optical input is for inputting digital audio into a PC via USB, similar to using the mic or line inputs. In other words, I don't think it will convert the optical input and pass through to the analog outs. But for $22, might be worth a try and could be a handy thing to have for one's computer.
    This is about the cheapest DAC I have seen - http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A
    You will probably need to make sure the digital out is set to stereo PCM in the TV, as a 5.1 DD broadcasts can't be decoded by 2-channel DACs.
    Given the availability of cheap USB sound cards for $20-30, I would think that a cheap DAC could be found in that same range (or a little more due to the need for a separate power supply)...but I haven't seen one for under $60.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
    heiney9 Posts: 25,412
    edited January 2010
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited January 2010
    May be too large for you but you could probably find a used avr that would do the trick for far less than these converters cost.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    H9 - did you see any specific low cost DACs in that search?
    All I saw were D-D converters and a couple A-D converters.
    APC needs a cheap DAC.
    APC, what's the primary source to the TV? Is it over-the-air broadcast?
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    DJ - I was thinking used avr too as a possibility, if space allows.
    For an avr, you would need to make sure that you can get an analog line level signal out when using a digital input. The avr's I've used will not allow this through the record out or multi-room analog outs. If the avr had front L/R preouts, there would be no issue. Also, I think the headphone output will work with a digital input, but not 100% sure in all cases.
  • apc
    apc Posts: 779
    edited January 2010
    Thanks - let's simplify this:
    TV Ears require analog left and right RCA jack input. I can use either a mono or stereo signal by using and adapter. This is not hifi - this is for hearing impaired parents. Signal does not have to be good - just audible :).
    The Vizio's optical output is digital and most all of the adapter/converters I've found or you suggested adapt the connector, but do not convert the signal to analog and I don't think that will work.
    monoprice had a nice one that looked perfect (http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2948&seq=1&format=2) but I think the disclaimer (This item is for digital signals only. Make sure your devices say digital in or out (single orange RCA connector). This item will NOT convert digital toslink to analog RCA (red and white RCA connectors).) rules it out.
    PS - no computers or other hardware available for this install. It's for their kitchen. They are NOT tech savy and added machinery would result in dust gathering for the whole setup :)
    Thanks again!
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    APC - yep, you need a simple/cheap DAC.
    Unfortunately, the cheapest one I've found is $60 (post #7).
    If I can think of something cheaper, I'll report back.
  • kcoc321
    kcoc321 Posts: 1,788
    edited January 2010
    What model Visio is it? Mine as coax, Toslink, headphone and audio L/R outputs....
    well $60 is pretty cheap for a DAC..
    I was thinking about a used receiver as well. how about a Mini stereo/ receivers like the little Denon M30's or so??
    I bet you could find one, or something similiar at the Goodwill for $20-30.. I have seen them or eq..just need to find one with the Toslink input, and of course, the audio output as well.
  • unc2701
    unc2701 Posts: 3,587
    edited January 2010
    Your cheapest option will be to just keep your eyes open for a AVR on craigslist/goodwill, as others have mentioned.
    I've helped a friend set up a system using the one linked from amazon- it's nice that it's plug&play and has low power consumption, but you'll need to be sure to pass it only PCM (doesn't do AC-3/DTS/encoded streams). For that price, I'd keep my eye on ebay for a B&K reference 20. They go for a little over $100 these days and you'll get a full featured pre/pro that can handle surround formats.
    Backburner:Krell KAV-300i
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2010
    Any thoughts on using a Digital Set-top box for the tuner? You know the ones required to watch Digital broadcasts on older non-digital TVs? Wasn't there also a $40 rebate or something on them as well?
    I'm assuming they don't already have cable since you could just use the analog outputs right from the cable box, right?
    ____________________
    Pool: Atrium 60's/45's
  • unc2701
    edited January 2010
    The rebate ones by law CANNOT output High Def. The rebate was solely to allow old TV's to get digital broadcasts. Kinda retarded, eh?
    Anyhow, I've been looking for a high def tuner box (sans rebate) & they seem to run as much as the DA converters we've discussed or more...
    EDIT: I'm assuming the TV is high def since Vizio is known for their LCD's...
  • mmadden28
    edited January 2010
    unc2701 wrote: »
    Well I guess that makes sense since the older sets wouldn't support Hi-Def anyway. While HiDef is a digital signal, the settop boxes weren't meant for HiDef, but to support the digital broadcasts at all.
    So, looks like the set top box is out (except for cable boxes).
    As suggested, except for a cheapo mini DAC, I'd probably look for a basic AVR/Processor to do the conversion then.
    I wonder if one can build a really basic cheap DIY converter. I did a quick search but most DIY DACs are geared towards better sound quality and so are more expensive or complex. After all why build a DIY DAC if you weren't trying to get better sound right?
  • apc
    apc Posts: 779
    edited January 2010
    It's a VW32LHDTV30A and the manual is a pdf on this page if you are curious:
    http://www.vizio.com/vw32lhdtv30a.html#support
    I've got 2 Vizios and my mom has another - all have simple, analog outputs and/or headphone jacks. This one does not.
    Thanks for all of your efforts and inputs.
    They do not have digital cable; therefore, no cable box. They have basic cable.
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    If it's basic analog cable, running the cable into a VCR to get the analog audio out is another cheap option.
    I know it adds another component, but there's no way of doing this without adding another component, whether it be a DAC, AVR, or VCR.
  • mmadden28
    edited January 2010
    I didn't think there was any such thing as analog cable anymore.
  • adam2434
    adam2434 Posts: 995
    edited January 2010
    mmadden28 wrote: »
    Our local Time Warner still provides the analog NTSC cable that doesn't require a converter box and connects directly to older TVs.
    I think I read somewhere that many cable companies will still provide analog cable until 2012. I guess after that, we'll need to rent or buy converter boxes for all of the old analog sets.
  • apc
    apc Posts: 779
    edited January 2010
    Here's my high-tech solution to the situation. As one might expect, the alternative was right under my nose. Little did we know that the manufacturer had this base covered. Thanks for all of your collective help.
    http://www.tvears.com/shopexd.asp?id=33
