PS3 Question....
shawn474
I have recently started using my PS3 to stream from Pandora which I like a lot. Also, I have ordered the Netflix DVD to be able to watch instantly through the PS3. I saw another thread related. I have a couple of questions.....
What other online radio stations are good through the ps3? How is the Netflix through the ps3 (basically is it worth it)?
Also, when I put a disc in or turn on my ps3, it takes me to my user id and I have to push enter to log on. It doesn't automatically log me in or start the disc. It always screws up the date and time because of this. Anyone have a solution to this problem?
Thanks in advance.
Shawn
Thanks in advance.
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
Post edited by shawn474 on
Shawn, can't answer radio station question bit when I inserted my Netflix disk the first time it provided a code that then required me to my computer to netflix.com/ps3 and enter the activiation code. Once I did the PS3 displayed my instant queue.
No logging in required on PS3 the first time. I have not tried a scond time but I do not think so.Speakers: SDA-1C (most all the goodies)
Thanks man. Appreciate the response. I figured out the problem with the user id - I didn't have it set up to automatically log into my user name when the unit powered on.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
DVD Player: Sony PS4 -
I usually use Pandora myself, but there is Jango as well. Never tried it on the PS3, but it is pretty much the same as Pandora.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I think LastFM is another one a lot of people at work use. Not sure if it works with the PS3 or not. I just use Pandora and netflix.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
I didnt care for the netflix streaming dont really care to watch movies in that poor of quility. I do use netflix I just order the BR movies. I understand you cant stream BR movies but the quility was really poor worse than vhs to me. If the quility was the same as a SD dvd I would use but until then didnt like it.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
how do you use the PS3 to do Pandora? Is it a download or do you just go to the web browser?Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I just go through the web browser; not sure if there is another way to do it.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
Shawn
Yup, just go there and make an account. As easy as that, no dl required.
-JeffHT Rig
Blu-Ray- 80 GB PS3
