Is speaker cable age a factor?
Jetmaker737
Jetmaker737 Posts: 1,122
Would there be any problems with speaker cables that are 8 or 9 years old but otherwise in good physical condition? Do they degrade with age?
I'm considering a purchase.
Thanks!
Jet
Post edited by Jetmaker737 on
    treitz3 Posts: 20,039
    edited January 2010
    Hello Jet, that depends on the cable in question. Which cable are you considering and what kind of terminations do they have?
  • Jetmaker737
    edited January 2010
    Hey t3, they are Audioquest Indigo + with spades.
    edited January 2010
    I'm not really familiar with that particular cable so I Googled some images. It looks like copper wire(s) with a gold plated termination. Knowing that, my only concern would be the copper tarnishing [will turn green] at the point of contact with the spades. If it was soldered on, there should be no issue. If the terminations were just screwed on, then I would recommend shortening the cables back an inch or two to where the tarnishing stopped and re-terminating with solder.
  • Jetmaker737
    edited January 2010
    Thanks! I believe these are soldered. If I decide to purchase I'll look over the terminations closely.
    Jet
