csi3 or csi5??
sammybocat
sammybocat Posts: 15
edited October 2003 in Speakers
Hey everyone,
I am upgrading my center speaker and want to know which one to choose. My system has just been completely overhauled.
Front: R50
Surround: RC80i
Sub: PSW303
Receiver: Pioneer VSX-D912K
Should I go with the bigger Csi5 or would it over power my system and therefore go for the Csi3?
Thanks for all you help!
Jeff
Post edited by sammybocat on
  • faster100
    faster100 Posts: 6,124
    edited October 2003
    I would try and first match your system, The models you mentioned are the "new" models.. i would stick with the R series or current rti's... you have a mix and i wouldnt add another sound into it with the new line
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2003
    I think you will find that the 5 will stomp all over the 3, just like the 40 did over the 30. There is no worry about it overpowering your other speakers, just make sure you have balanced levels. The 5 will have much more low end, giving voices, etc. a much more natural sound.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2003
    ****, just pick one. It's a damn center channel, which you are probably going to set to 'small' anyway.
    Cheers,
    Russ
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2003
    Buy the biggest center channel you can, that timbre matches, or is similar to what you own.
    HT = Center Channel. Basic statement, but most of your data is thru the CC.
  • RuSsMaN
    edited October 2003
    So bigger is always better for the center channel? What a crock.
    I take it that theory didn't apply in *your* rig? ;)
    Cheers,
    Russ
  • dorokusai
    edited October 2003
    I think that the bigger center channel the better, but the other speakers need not be huge if using a subwoofer, yes. 50+% HT is thru that damn thing.
    I have the CSi30 because I couldn't afford the CSi40 at the time. I am going to replace it when they come down in cost. I apologize for being poor.
    Throw rocks at that fat kid Russ, you fooker :)
  • fireshoes
    edited October 2003
    I'd say bigger is better if it's in the same line. :)
  • Mazeroth
    Mazeroth Posts: 1,585
    edited October 2003
    dorokusai, I'm laughing my **** off at your last line LoL! :D
  • LiquidSound
    LiquidSound Posts: 1,261
    edited October 2003
    So bigger isn't always better? Why doesn't that apply to russman's ****? Sorry russ..ya set yourself up.:D
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
