Turntable Noise?
TomB
TomB Posts: 106
edited January 2010 in 2 Channel Audio
I was listening to my circa-1982 Denon DP-31L turntable (direct drive), and heard a noise on quiet passages of classical music that I would describe as sounding like something heavy being rolled across the stage during the performance.
If I watch the platter, it seems that the noise occurs as the same section of the record/platter reaches the needle.
I was listening through headphones, so I know it's not feedback or speaker- induced rumble.
Am I hearing noise from the motor/bearings? Is there a fix, other than a new table? Would one of the entry-level tables from Rega, Pro-Ject or Music Hall (all belt drive) be a major improvement?
Thanks for any help.
Post edited by TomB on
  • jimmydep
    jimmydep Posts: 1,305
    edited January 2010
    I have a Sony direct drive TT, and have noticed the same rumble sound on very low passages at high volumes. I don't notice it while playing at normal volume and it is a very faint sound. When I use the Bren 1 weight it seems to lessen if not eliminate the sound completely. and I've noticed a slight increase in the low end with crisper highs while using the weight (thanks to Keiko).
    I'm sure more experienced members will have better advice for you.
    Jimmy.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2010
    Common TT problem. The vinyl album is like a conductor/amplifier of everything it picks up vibration wise from the turntable mechanics, room vibration, sound waves, etc. and the cartridge then picks that up along with the good vibrations from the record groove. A heavier platter will help, so will more solidly connecting the record to the platter (as in the weight mentioned above), or a good TT mat like the Herbies mat referenced in at least one other thread in this forum.
    All the above assumes there is no operational problem with the TT, such as a bad bearing, unbalanced or unlevel platter, etc.
    DKG999
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    dkg999 wrote: »
    That was going to be my question. Also direct drive tables can introduce motor noise to the platter which sounds like rumble.
  • HB27
    HB27 Posts: 1,518
    edited January 2010
    I just trashed my DP 47 due to the same type of noises. I isolated it to the bearing on mine. I used an automotive stethoscope to find the problem
    Best of luck eleminating the noise.
  • hearingimpared
    edited January 2010
    HB27 wrote: »
    Was the bearing shot or in your opinion is it because of the direct drive design?
    mhardy6647 Posts: 34,993
    edited January 2010
    Is that one direct drive (I assume so)?
    I would say, if possible, lubricate the main bearing with a drop of high quality light oil.
    If it is belt drive, I'd further recommend changing the belt and cleaning the motor and platter pulleys thoroughly with something like isopropanol.
  • hearingimpared
    edited January 2010
    Customer Service at VPI recommended that I put a drop of 10w 30 motor oil on the shaft and bearing. DO NOT use vegitable oil or anything like it.;)
  • dkg999
    dkg999 Posts: 5,647
    edited January 2010
    Slick50 will quiet things right down :)
    DKG999
    edited January 2010
    Typically something like sewing machine oil or clock oil.
  • hearingimpared
    edited January 2010
    I thought 3 in 1 oil got gunky over time?
  • jimmydep
    edited January 2010
    I'm surprised VPI would recommend using motor oil and not a high grade pump oil, or sewing machine oil. 3 in 1 should work just fine.
  • hearingimpared
    edited January 2010
    jimmydep wrote: »
    Why do you find that surprising Jimmy?
  • HB27
    HB27 Posts: 1,518
    edited January 2010
    in my case it was the bearing. They're actually a very quiet DD table when working properly.
    The first issue I had with it was the speed control (typical) and then the bearing. It got so bad at the end of it's useable life that you could hear it all the time.
  • TomB
    TomB Posts: 106
    edited January 2010
    Thanks for all the suggestions. I think I'll try (a) oil; (2) a weight; and (iii) a mat, in that order.
    Everything is level - how does one check a platter for balance? (It's the stock aluminum platter that came with the table.)
  • hearingimpared
    edited January 2010
    TomB wrote: »
    With a round bubble level. Be careful though some platters are slightly dished.
  • mhmacw
    mhmacw Posts: 832
    edited January 2010
    hi tomB, i dont in any way shape or form want to discount anything that has been said or posted by anyone previously. however, if it was me i would talk to darknight(sp?) and be it as gospel. he is a tt freak and will have the goods no matter what the problem. just my humble for what its worth.
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2010
    Did anyone suggest you get a belt-drive turntable ??? i'd suggest a Dual
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
