Computer Error Screen - Help!
audiobliss
audiobliss Posts: 12,518
edited January 2010 in The Clubhouse
My dad reports he sees this same error screen quite frequently on his desktop. It's a Dell Vostro 200 that otherwise has served him pretty well. This error screen will be up when he returns to the computer after it has set idle for a few hours. And just while ago it actually popped up on him after he had resumed using it after it sat idle for a few hours.
A problem has been detected and Windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file:
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
*** STOP: 0x400000080 (0x8A442658, 0x89ED6CD8, 0x805512B8, 0x00000002)
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for further assistance.
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • Demiurge
    Demiurge Posts: 10,874
    edited January 2010
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    I only wish I had three tongues!
    Ben
  • audiobliss
    edited January 2010
    Guys, really?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Jstas
    Jstas Posts: 14,995
    edited January 2010
    Dude, it's a blue screen of death otherwise known as a stop screen. They occur when something, a program or other resource, tries to access a system resource like the memory controller directly. Windows freaks out because it then no longer knows what's in memory and halts the system.
    The problem with it is that when the system halts it's a hard stop and system files and boot volumes often get corrupted and the only fix is a complete reinstall.
    He likely has a virus or the remnants of a virus causing the problem. Either that or he installed some new hardware or software with crap code and/or crap drivers.
    But there is info missing from that error that is vital to figuring out what is wrong.
    Number one, this is incomplete:
    The problem seems to be caused by the following file: ?????????
    Where's the file name?
    Number two, this info:
    is pertinent. Google the numbers.
    0x400000080
    0x8A442658
    0x89ED6CD8
    0x805512B8
    0x00000002
    You will find info on what could be the possible issue. But without that file name, you won't be able to be sure what the issue is. You need more info.
    Expert Moron Extraordinaire
  • ben62670
    edited January 2010
    Could be malware witha fake blue screen too. Take the hard drive out and scan it on a clean machine.
    Ben
    Ben
  • audiobliss
    edited January 2010
    Thanks for the input, fellas. I'm fairly sure it didn't actually list a file name, but I'll look specifically for that the next time it pops up.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited January 2010
    Oh, and yes, I'll run some programs on it to check for viruses, malware, and make sure the hardware all checks out.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    billbillw Posts: 7,744
    edited January 2010
    It should list a file. Usually an exe, sys, or dll file. These will occur when something has changed. Software update, driver update, or hardware change.
    If it occurs randomly with no system changes, then you could have a bad memory stick or some type of hardware error (these are rare).
    It might also be a fake screen, but I haven't heard of those. If CTRl-Alt-Del doesn't do anything, then its probably a real BSOD.
    Things to do:
    Run Memtest for several hours and see if there are any errors.
    Think about any changes you have made. Check MS Update history for driver updates and possibly reverse them.
    Sometimes even minor things can cause this, like inserting a flash drive or something.
  • exalted512
    exalted512 Posts: 10,734
    edited January 2010
    my netbook has started doing that seconds after I boot it up. Havent had time to mess with it.
    -Cody
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited January 2010
    Also, something a lot of people overlook when it comes to BSODS: Over-heating.
    If your cpu/video card/ram get too hot, they can and often times do throw out a BSOD. The best way to tell is if it happens at completely random times, and with no pattern (not after opening a program/game, etc).
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Sami
    Sami Posts: 4,634
    edited January 2010
    First things first: memory test. If you still have your Ubuntu discs somewhere, pop it in and there is an option to run memory test. If you don't have it, download and burn memtest86. Make sure your BIOS is set to boot from CD first, then insert the CD and boot up. If memory test comes up clean then you can move into other possible causes but if the BSOD does not happen every time it is booted up, memtest should be your first step.
  • audiobliss
    edited January 2010
    Just ran the memory test on it for probably an hour and a half and it checked out. Also ran AVG virus scan and let Malware Bytes scan it. AVG found nothing, and Malware Bytes found some "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e4168e07bb}
    The error screen popped up again so I took another look to see what file it listed as being the problem, and as I had thought, it does not list anything there. There is nothing after the colon, just an empty space and then the rest of the error report as I provided.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2010
    did he remove any programs that have a shared .dll file. Have you tried a system restore?(not a reistall)
  • audiobliss
    edited January 2010
    Haven't tried going back to a restore point yet, though I suppose that's our only real hope; he doesn't have any discs for reformatting. However, he's going to call the store he bought it from and see if he can acquire a disc for reformatting.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Sami
    Sami Posts: 4,634
    edited January 2010
    Next step would be core temperature as I still would not rule out hardware failure. Do you still have that Ubuntu disc? Insert it and boot into live mode. Install cpuburn by running this command from command line: sudo apt-get install cpuburn
    Run one of the burnin tests based on the CPU type:
    type in burn and then hit Tab to get the options.
    I recommend this option over cpuburnin for Windows to rule out any software clitches.
    Another option is to install Core Temp and enable logging on it automatically: http://www.alcpu.com/CoreTemp/
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited January 2010
    Try the pin reset on your motherboard as well as removing the battery on it. And if you are doing this, make sure everything is in place on the board.
    Halen
  • audiobliss
    edited January 2010
    I actually do not have an Ubuntu disc here at home with me. I just happened to have Memtest on a flash drive in my backpack. I was thinking about installing Speedfan or or something similar to see what kinds of temps it was seeing.
    Looks like Core Temp might be a better option. I'll go try and install that now.
    Argh, I'm fed up with technology right now. Between Dad's desktop, setting up VCR's, DVD players, and cable boxes in different rooms in the house, and not being able to play DVD's on my laptop with Ubuntu, I'm ready to just go sit in the woods and carve in a piece of wood by firelight! :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Sami
    Sami Posts: 4,634
    edited January 2010
    audiobliss wrote: »
    If that log shows gradual temp rise until BSOD then you might want to take out the CPU fan and put in new thermal crease. Could also be failing fan. If there isn't anything related to temperature, download a LiveCD and run burnin tests. If those burnin tests pass then you can safely say it's a software issue.
    audiobliss wrote: »
    Have you installed CSS on it? Hopefully this will help: http://www.debuntu.org/how-to-play-dvd-under-ubuntu-linux
  • audiobliss
    edited January 2010
    Thanks for that link Sami. I've tried I don't know how many times from how many different sets of instructions I've found online, but it always comes down to trying to install libdvdcss2, and that NEVER works. It can never find it or says command not found.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Sami
    Sami Posts: 4,634
    edited January 2010
    audiobliss wrote: »
    You could try this:
    wget http://download.videolan.org/pub/libdvdcss/1.2.9/deb/libdvdcss2_1.2.9-1_i386.deb
    sudo dpkg -i libdvdcss2_1.2.9-1_i386.deb
  • audiobliss
    edited January 2010
    That is so awesome! It worked! Thanks so much!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2010
    audiobliss wrote: »
    ..., setting up VCR's...
    :confused::eek::rolleyes:
    What does V...C...R stand for? And don't tell me to google it dammit.
    ____________________
    Pool: Atrium 60's/45's
  • audiobliss
    edited January 2010
    mmadden28 wrote: »
    ixquick it
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • mrbofus
    mrbofus Posts: 297
    edited January 2010
    I just got to work this morning and the boss left his computer on last nite, it is displaying a very similar message on the blue screen. wierd????
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
    Onkyo DX-C390 CD Changer
    POLK RTI8 Mains--Cherry
    the rest...in process...slowly!!
  • Jstas
    Jstas Posts: 14,995
    edited January 2010
    mmadden28 wrote: »
    Video Cassette Recorder.
    What's a cassette?
