Are my SDA's 1B's or C's??
wingzam
Well i've been lurking in the background for a while just enjoying the threads and posts but came across a post that got me confused so need some clarification.My SDA's were advertised as 1B's,the boxes (which are buried) I think only said SDA-1.
A member described his SDA-1's as the C version because they only have 1 pair of binding posts,whereas the B version has 2 pairs.Can anyone confirm this?I need to know because I plan on going thru the crossovers,etc..Also are the crossovers the same on these 2 versions?
Finally,i've run across a term I can't figure out - "TL modded" - what the heck does that mean??
Thanks!
Thanks!
Post edited by wingzam on
Can you post a pic or describe the driver arrangement?JC approves....he told me so. (F-1 nut)
Pictures tell a thousand words... post up some pictures ot the front and the rear, especially showing the binding post/interconnect socket and that will help out a lot.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I don't know of any 1C's that use (2) sets of binding post from the factory. If any 1C would have it would have been the last production which were 1C's..........never seen one, read about one or sold one in the day."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
1B's are Blade/Blade SDA connectors. 1C's are Pin/Blade connectors. There may be a few transitional 1C's that are Blade/Blade with only the Top Blade being used for SDA. 1B's are 4ohms and 1C's are 6ohms.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Man you guys are fast!Thanks!The interconnect has a larger blade and a smaller blade - is this smaller blade considered a pin?There are two tweeters on top stacked length wise one above the other and centered in the middle of the cabinet,4 drivers and the radiator at bottom.It's easier to describe then trying to figure out how to post a picture on short notice.
The pin is round. You most likely have 1B's.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
do they look like these
http://www.polksda.com/sda1c-studio.shtml
or these
http://www.polksda.com/sda1c.shtmlJC approves....he told me so. (F-1 nut) -
george daniel wrote: »do they look like these
or these
Yes,thats the same speakers,and with the "Silver Coil Dome" tweeters -
Oh,looking at the second link,those speakers are sitting flat on the ground whereas mine have built on,what? pedestals about 2" tall.
Far as I know--and no doubt someone will set me straight...
1Bs have vinyl woodgrain over chipboard; and they sit on short pedestals.
1C have real wood laminate on top and bottom, no pedestal...except for the "Studio" 1C which looks just like a 1B except in black or black vinyl woodgrain instead of dark brown vinyl woodgrain like a 1B.
The Studio 1C has the same drivers as the "real" 1C; and I suppose the same crossover as the 1C although I was reading that someone (I forget who) was saying there's two versions of the 1C crossover--a two-piece unit (early) and a 1-piece unit (later).
And of course there are "transitional" versions, too. It does get complex.
For me, the main issue would be the interconnect cable. Two blades = 1B; pin/blade = 1C.
The pin/blade is beneficial because then you dont "HAVE" to use a common-ground amp; you have the option of bridged amps and/or monoblocks if you use a SPECIAL interconnect cable having a transformer in it. -
That's called an AI-1 cable. -
Sounds like I have the B's,but am still wondering about the 1 pair of binding posts verses the 2 pair of binding posts configuration that I mentioned in the original post..
There are 2 versions of the x-over unit and according to the Stereo Review Magazine only the later single x-over board unit come in both studio and regular.
The 1 piece x-over 1C's use different drivers (side wound voice coils similar to the SRS of the day) and are 6 ohm. The 2 piece X-over units use a slightly older drivers and are 4ohm. I believe many have said there are sonic differences but they tend to be subtle and the later (single board x-over's) are a little simpler and again according to Stereo Review are more coherent.
Here's the review of the last production single x-over board 1C.
http://www.polksda.com/sda1creview.shtml"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
There was no such thing from the factory.
OK heiny9 i'll pass that along and thank you all for the help!
now I'm thoroughly confused,,did we determine which model SDA's that you have?:):confused:JC approves....he told me so. (F-1 nut)
george daniel wrote: »now I'm thoroughly confused,,did we determine which model SDA's that you have?:):confused:
Haha!!Ya Daniel i'd say it's unanimous that they're the SDA-1B's.All this confusion began with a post by a member (who will remain nameless) that made the comment that the B's had 2 pair of binding posts and the C's had one pair...well,reading down the thread nobody made a correction so i'm all excited thinking i've got C's,but wanted to double check before I started going thru them.
A little disappointment a day makes the heart grow fonder..or something like that..but hey - i've got a nice pair of 1B's and that doesn't suck! -
Nobody said that either had 2 sets of binding posts. H9 staed the B's had a two piece XO. IE two boards.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
well for what it's worth i have the black studio 1C's one pair of binding posts and 6ohm's rated impedance...
for that it's worthYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Probably need pics to determine for sureNobody said that either had 2 sets of binding posts. H9 staed the B's had a two piece XO. IE two boards.
The OP did see below my highlightWell i've been lurking in the background for a while just enjoying the threads and posts but came across a post that got me confused so need some clarification.My SDA's were advertised as 1B's,the boxes (which are buried) I think only said SDA-1.
Thanks!
Ben the following info was sent to me which along with the original post,led to my confusion:Nobody said that either had 2 sets of binding posts. H9 staed the B's had a two piece XO. IE two boards.
John,
The reason I put the caveat into my statement is that I am not an SDA guru. The information I stated was pulled from my understanding of the orignal manuals that came with the speakers. Basically, the first manual was for the SDA 1B which showed the dual binding posts. There was an addendum manual with updates for the 1C's which shows the single binding posts. Either way, they are both SDA-1s and my manuals didn't say SDA 1-C on the front. They cover several SDA 1 series speakers. I don't know of any other identifiers for the 1C's. Not sure what TL modded means but it might have something to do with the tweeters having been replaced. That's a good question for the SDA experts on the forum. -
Nope, never happened.Political Correctness'.........defined
President of Club Polk -
I consider myself well versed in SDA's, but F1nut knows more than nearly anyone hear when it comes to SDA's;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Got me:DPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Mine are happy - they've finally discovered their true inner selves!
Glad to hear you are enjoying them:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Now can someone tell me what "TL modded" means????
The TL mod refers to modding the XO to use the 198 replacements instead of the 194 replacements. Stick with the 194's and drop them in. Also consider strongly upgrading the crossovers.
Ben -
Aaaahhhhh,now all my questions are answered!!
But wait a minute,since i've got the Gurus on the line - what is the meaning of life??
