Subwoofer Enclosure
Systems
I just but bucket seats in my 1989 ford Ranger and i am going to make a box between the seats. It can be about 2 1/2" long and about 1' foot wide and only a 1' or 1' 1/2" tall. I am looking for plans to make a bandpass box for those specifications. If you have any suggestions on where to find plans of that nature or if you can help me. reply. thanks
Testing
Testing
Testing
Testing
Testing
in a truck I'd just go with a sealed box, just my opinion.Testing
Testing
Testing -
you should go downfiring and sealed.
to do a bandpass in a pickup is suicide -- when you open your windows its going to sound like absolute ****.The Artist formerly known as PoweredByDodge -
I have to agree with PBD... :cool:
Random question, nothing really to do much with this post, I just didn't want to start a new topic. When specs are given for a box and they say 0.6 cu ft does that mean the volume of the box without the sub in there or do i need to make the box a tiny bit bigger to accomodate for the volume the subs taking up?
ThanksTesting
Testing
Testing -
if the specs are listed with the subs...the displacement is included...if it says .6...its .6
-Cody
