Pick my next router
Shizelbs
Okay computer nerds. Here is what I want...
A new wireless router. Wifi N, wired ports in the back, not too ugly, reliable (something my Linksys is not the best at), dual band would be great, and one that I can plug USB devices into (preferably a USB hub plus a couple devices), then use those devices over the network by a couple different computers. AND, are there any that will stream audio from my computer and have analog outs? Something like what Apple's Airport Express, or whatever does. Something not Apple, I don't want to spend money on Apple products.
What do I get?
What do I get?
Post edited by Shizelbs on
I just ordered this combo from Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127215
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127082
http://www.newegg.com/Product/Product.aspx?Item=N82E16833996013
It will do most of what you need.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
