Have my cables hooked up to a turn table, or can hook up my cables email me.
ben62670
I need a little help with my cables design for TT's. I am getting mixed reviews with the silvers on the turntables. I am looking at an affordable option with better sound hopefully. The problem seems to be too low a capacitance with some PhonoPre's. Please contact me via email. It is my Polk screen name at yahoo.com I have a proposition for you time. So far it is working well with my system. A side note is that if you never burned them in on a CDP for at least 80hrs you are doing your system a big disservice
Ben
Ben
Ben
Ben
Post edited by ben62670 on
Ben, I had your silvers hooked up from from my phono stage to pre and had no real complaints. I went with MITs ICs on everything is the reason they came out.Speakers: SDA-1C (most all the goodies)
The only problem I ever had with your silver ICs is when I hooked them up between a step-up transformer and my phono pre. I got a very loud hum. Other than that they work very well. I now have them in my HT rig as I've upgraded to all MIT ICs in my 2 ch rig.
I have your silver IC,s in my whole system with no complaints.
From phono pre to preamp Ben's IC's
From my pre to amp Ben's XLR's
From CDP to preamp Ben's XLR's
Ben's custom SDA cable
My speaker cables are MIT's
of course my TT cable is the stock cable.
Did you ever get the gift I sent you? -
Not here yet. Why is the TT cable stock? You and Tracy are already on my list;)
Joe The hum is the issue. Some pre's have no hum, and some do. I have some COAX solid copper 18ga center conductor. The inner insulation is foamed teflon, and the braid is copper not tinned wire. The cable is more expensive than other wire, but the 18ga wire, foamed teflon, and copper braid seem to be worth it from listening tests that I have done so far. I have tried them on my Phono, and tubed Pre. It's too early to give reviews, and I want to get opinions from others to see if there is any synergy issues.
Ben
