Anyone using a Denon AVR-5600?
glemay
glemay Posts: 574
edited January 2010 in Electronics
Hey,
Just wondering if anyone here is using a Denon AVR-5600. I know it's an older receiver and doesn't have many of the new features or audio formats found on today's units, but I'm guessing it would work great for primarily music system. I can't really find much on it on the web as far as specifications go, but which audio formats does it play? Anything I should know if I decide to pick up one of these locally. What are they worth today?
Thanks,
Jerry
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • glemay
    glemay Posts: 574
    edited January 2010
    I can pick one up for $225, what do you guys think? What would it be like compared to my current Denon AVR-2805?
    Jerry
    Main System:
    Second System:
  • Conradicles
    Conradicles Posts: 6,334
    edited January 2010
    $225 is a steal. Buy it.
  • glemay
    glemay Posts: 574
    edited January 2010
    Anyone know who do to a system reset on this unit?
    Main System:
    Second System:
    tonyb Posts: 33,068
    edited January 2010
    Thats a steal for that unit,snatch it up or let one of us. You can use that receiver with the new audio formats by way of the analog inputs. Check the online owners manual or shoot over to the owners thread at the AVS forum for info on resetting.
  • Conradicles
    edited January 2010
    glemay wrote: »
    On my lower model Denon which was built the same year here is what you do:
    1. Unplug the unit
    2. Press the speakers A and B buttons together and hold them
    3. Plug in the unit
    4. The display will flash a few times
    5. Let go of the A and B buttons
    6. That is called reseting the microprocessor to the factory defalts
  • glemay
    glemay Posts: 574
    edited January 2010
    The seller will be dropping the unit off on monday, can't wait.:) This should be pretty interesting. Tony, what do you mean by way of analog inputs?
    Jerry
    Main System:
    Second System:
    tonyb Posts: 33,068
    edited January 2010
    glemay wrote: »
    Jerry
    I'm assuming you ment the new audio formats as the ones that blu-ray offers. If so, your blu-ray player must have analog outputs that can be connected to most any receiver with analog inputs. Know what I'm saying chief?
  • Conradicles
    edited January 2010
    That way the blu-ray player will do the decoding of the hi-res formats and pass them to the AVR-5600. You got a great deal.
  • glemay
    glemay Posts: 574
    edited January 2010
    I know you guys are saying, but I'll have to pick up a bluray player before I have to worry about that. Thinking about waiting till I upgrade or buy a new computer and then just use that as a bluray player. Which formats does the AVR5600 support? Does it have DTS, or was that before its time?
    I need to go find a manual for this thing...
    Jerry
    Main System:
    Second System:
    tonyb Posts: 33,068
    edited January 2010
    Google is your friend.
  • glemay
    glemay Posts: 574
    edited January 2010
    I know tony, but you guys are just so resourceful :p.
    And thanks conradicles for the instructions on how to do a system reset. It's appreciated.
    Jerry
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited January 2010
    Hmm... I can't seem to find an online manual for the 5600. Any body have a link? I searched AVS forum and Home Theater forum, but can't find anything.
    Jerry
    Main System:
    Second System:
    tonyb Posts: 33,068
    edited January 2010
  • glemay
    glemay Posts: 574
    edited January 2010
    Well, I've just discovered how large this unit is, depth to be more specific. Turns out, the unit is just under 20 inches deep, about 3 or 4 inches more than I anticipated. Because of its size, it won't fit on my desk, where my current receiver sits (only 17 inches deep). And the other area I was hoping of using it is a built in cabinet space only 20 inches deep. So now I'm not sure I will be able to even use this monster. :(
    If the seller is still willing to bring the unit by under these circumstances, and I decide to pass, is there anyone here that would like the seller's information so they might be able to pick up this unit? I'm in Windsor, Ontario. Close to Detroit, Michigan.
    Jerry
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited January 2010
    Well, I just spoke with the seller. He measured it for me with an RCA on the rear, just over 20 inches. The cabinet I wanted to put it in in just under 20 inches deep, so, it won't fit anywhere... Seller seemed pretty upset when I told him I couldn't use it. But I made an honest mistake. I was unaware of how deep it was, and made an effort to let him know that I might not be able to use it before he made the drive out here. I even gave him the option to not make the drive out given the circumstances... I'm not going to buy something I can't use.
    Am I in the wrong?
    Jerry
    Main System:
    Second System:
  • alton
    alton Posts: 3
    edited January 2010
    Hi,
    If your bag is home theater this receiver is BAD ****. But unfortunately I'm bored with the whole home theater deal. I am going to get back into good old fashioned stereo music. That is where the 5600 fails music through my Def-Tech 2000 sounds to high even with 500 watt subs in each. But if your looking for excellent home theater dynamics and punch look no further this baby delivers the goods. Excellent channel separation and oodles of power and a 1st rate pre-amp section. If you want a great home theater system this is the way to go if you can find them. If not E-Mail me and I'll sell you mine.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited January 2010
    I just picked up a used Denon 5800 with the Aktis RC-8000 LCD touchpanel remote control. I have read that it is hard to use and to get the unit set up.
    Anyone have anye xperience with this remote? and any thoughts about it?
    Thx.
    Mike
  • glemay
    glemay Posts: 574
    edited January 2010
    Hey Alton, I'm just gonna sit tight for awhile. Thanks for the offer. No idea on the 5800 and its remote Neil.
    Jerry
    Main System:
    Second System:
  • Deadof_knight
    Deadof_knight Posts: 980
    edited January 2010
    I just got on off of the bay and its a beast got to be the heaviest avr I have ever lifted so far ... jeash !!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • brianbjg
    brianbjg Posts: 1
    edited January 2010
    After all these years, I finally replaced my Denon AVR-5600 with an AVR-990, mostly for the hdmi stuff and DTS/TrueHD decoding.
    It's now looking for a good home, so if anyone's interested please let me know by email (brianbjg@tekserv.com) with an offer. It's in great condition and has the original remote. The remote was hardly used, as I have a pronto universal. Also, this unit does not have the DTS upgrade.
    I can ship it, or if you want to pick it up, I live in the Boston, MA area.
