Wiring RT16 Speakers
leftyfarmer
leftyfarmer Posts: 30
edited January 2010 in Vintage Speakers
I just purchased a pair as I am attempting to wire to amp discover 4 posts
per speaker, any ideas how to safely setup these speakers?
Post edited by leftyfarmer on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2010
    Welcome to club polk.
    I am assuming you mean RTi 6 speakers? There should be some gold colored jumpers between the two sets of binding posts, and I would recommend you attach your speaker wire to the bottom posts although it really doesn't matter. If there is no gold jumpers between the post just use a short length of speaker wire between the post and you should be good to go.
    Pop on your favorite music and Enjoy,
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • leftyfarmer
    edited January 2010
    Scott, the model number is RT16 they are one of the first in the Reference Theater series
    I was able to get the spec's off from the Polk Audio site but there was nothing about how to wire them. Thanks for the info because the gold jumpers are in place. I have connected them with an old pair of Monitor 7's recently purchased, they sound great together.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    WElcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • dougr
    dougr Posts: 124
    edited January 2010
    With lots of power :) the RT16s don't really open up without some nice power driving them.
    ______________________________________________
    RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable :)
  • messiah
    messiah Posts: 1,790
    edited January 2010
    Ok, first you want to leave the jumpers in place (assuming they are still there). They are the metal plates connecting the top and bottom posts. If you are wiring normally, connect to the bottom posts. Bi-wiring is what the separate set of posts are for, so you'll be needing external amplification. Hope this helps.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • leftyfarmer
    edited January 2010
    All good I followed Millerlite's suggestion, the jumpers were in place, hooked up to a Marantz SR66, they sound excellent to me.
