SDA 1.2tl + 2.3tl HT
bdaley6509
I plan on using my 1.2's for mains, and 2.3's for rears. I know it's probably overkill for the rears, but I got a great deal on the speakers and I will never sell them. Anyway, my question is, should I still use the SDA interconnect cable for the rears for home theatre, or not. Also, do I have to put the left surround 2.3 speaker on the right hand side and vice-versa? Thanks.
Post edited by bdaley6509 on
Using your 2.3TL's for rear is useless. I'd tried that before, it doesn't do anything good. The best to timber match your
TL version SDA's, if you can find one, is the RTA 11TL's that will work OVERKILL.
Har -
It actually sounds really good. I am happy with my setup.
