Infected Computer....
Systems
Systems Posts: 14,873
edited December 2009 in The Clubhouse
I worked on a computer yesterday that was infected pretty bad. Thought you might get a kick out of the Malwarebytes log. I give testiment to this program as it did an excellent job of cleaning up the computer, theres still issues, might still have to reformat
Malwarebytes' Anti-Malware 1.42
12/28/2009 10:39:52 PM
Memory Processes Infected: 1
Memory Modules Infected: 4
Registry Keys Infected: 13
Registry Values Infected: 10
Registry Data Items Infected: 13
Folders Infected: 3
Files Infected: 42
C:\WINDOWS\Temp\tempo-291968.tmp.exe (Trojan.Agent) -> Unloaded process successfully.
C:\WINDOWS\system32\diwunawo.dll (Trojan.Vundo.H) -> Delete on reboot.
c:\WINDOWS\system32\fuweyofa.dll (Trojan.Vundo.H) -> Delete on reboot.
C:\WINDOWS\system32\polapoho.dll (Trojan.Vundo.H) -> Delete on reboot.
C:\WINDOWS\system32\dbbin.dll (Trojan.Goldun) -> Delete on reboot.
HKEY_CLASSES_ROOT\CLSID\{f338e0a0-d3b7-4df9-af4b-a8feb2464c2c} (Trojan.Vundo.H) -> Delete on reboot.
HKEY_CLASSES_ROOT\CLSID\{9bc9c69a-6384-4a7c-a4d3-f8c697f4253f} (Password.Stealer) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\dbbin (Trojan.Goldun) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\DvidPL (Trojan.DNSChanger) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\dbbin (Trojan.Goldun) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DvidPL (Trojan.DNSChanger) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SafeBoot\Minimal\dbbin.sys (Trojan.Goldun) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SafeBoot\Network\dbbin.sys (Trojan.Goldun) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_ESQULSERV.sys (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_Windows_MSI (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\ESQULserv.sys (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Windows MSI (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\idid (Trojan.Sasfix) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\jakuguvof (Trojan.Vundo.H) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\{f338e0a0-d3b7-4df9-af4b-a8feb2464c2c} (Trojan.Vundo.H) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\suvimaley (Trojan.Vundo.H) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\jliqosexasuxomod (Trojan.Agent) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\bn (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\d1 (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\d2 (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\d3 (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\gd (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MSN\pr (Trojan.Ambler) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\LSA\Security Packages (Trojan.Vundo.H) -> Data: diwunawo.dll -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\LSA\Notification Packages (Trojan.Vundo.H) -> Data: pobdmi.dll -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\AppInit_DLLs (Trojan.FakeAlert) -> Data: c:\windows\system32\cru629.dat -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\AppInit_DLLs (Trojan.FakeAlert) -> Data: system32\cru629.dat -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\AntiVirusDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\FirewallDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\NameServer (Trojan.DNSChanger) -> Data: 85.255.112.210,85.255.112.65 -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{ca36886c-6d8a-491f-8e4c-6947b7902071}\NameServer (Trojan.DNSChanger) -> Data: 193.104.110.38,4.2.2.1,192.168.2.1 -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{ce632e0d-adcf-4abf-8549-3154d82119d0}\NameServer (Trojan.DNSChanger) -> Data: 193.104.110.38,4.2.2.1,216.129.224.1 -> Quarantined and deleted successfully.
Folders Infected:
C:\Program Files\DvidPL (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Documents and Settings\Travis\Start Menu\Programs\DvidPL (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\WINDOWS\addins\addins (Trojan.Agent) -> Quarantined and deleted successfully.
Files Infected:
C:\WINDOWS\system32\buyenayo.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\fuweyofa.dll (Trojan.Vundo.H) -> Delete on reboot.
C:\WINDOWS\system32\hafedeku.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\kiyajeru.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\kozezupo.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\kujonuva.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\viriteda.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\pobdmi.dll (Trojan.Vundo.H) -> Delete on reboot.
C:\WINDOWS\Temp\tempo-291968.tmp.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\smyrp.dll (Password.Stealer) -> Quarantined and deleted successfully.
C:\blyuwrjl.exe (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\fyblb.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Program Files\DvidPL\Uninstall.exe (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\WINDOWS\cru629.dat (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\tapi.nfo (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\winuid.dll (Spyware.Passwords) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wisdstr.exe (Rogue.PC_AntiSpyware2010) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\stray.dll (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\cru629.dat (Trojan.FakeAlert) -> Delete on reboot.
C:\WINDOWS\system32\softwares.dll (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\uinput.dll (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\mirc.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\tempo-291968.tmp (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\92.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\9C.tmp (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\9F.tmp (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Travis\Start Menu\Programs\DvidPL\Uninstall.lnk (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\Documents and Settings\Travis\Application Data\wiaserva.log (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\~.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\a9k.bin (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\dbbin.sys (Trojan.Goldun) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\msihost.exe (Trojan.Downloader) -> Delete on reboot.
C:\WINDOWS\system32\z98a.bin (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\tempo-291750.tmp (Trojan.DNSChanger) -> Quarantined and deleted successfully.
C:\WINDOWS\braviax.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\ogavilitaciwiman.dll (Trojan.Agent) -> Delete on reboot.
C:\xvhu.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Temp\d.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
Testing
Testing
Testing
  • Polkersince85
    Polkersince85 Posts: 2,883
    I hope you washed your hands when you got through.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Well anti malware will help you just have to use it. Anti virus software will not protect you against this new threat. Luckily you were able to remove it all. Most malware can not be removed after a certain point.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • bigaudiofanatic
    That is what we call, cut your loss and clean out. It is not worth trying to remove something that has infected most of the computer. Better to start over.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Knucklehead
    Knucklehead Posts: 3,602
    another good program to use thats free is "a squared" or "super anti spyware".
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Sherardp
    Sherardp Posts: 8,038
    +1 on this. I would'nt have bothered trying to remove any of it. After backing up pics, favorites, documents, etc. I would have formatted and been done with it in about 20 minutes.
  • Willow
    Willow Posts: 11,231
    If I read it right, tell Travis....to stop going to **** sites ;)
  • Systems
    Willow wrote: »
    Yes, his Mom is going to be pissed anyway:) I did that scan mainly to show her. Am going to do a format, kinda the plan all along as soon as I saw all that...The computer is still "talking" to the net at an idle....
    Testing
    Testing
    Testing
  • vlam
    vlam Posts: 282
    I've been troubleshooting more of these types of rootkit infected computer lately and the best way to handle them is the clean wipe of the OS and re-install. They are just very time consuming to troubleshoot and I don't even feel confident that it's totally gone after a couple hours of cleaning. Formatting the drive is the safest way to go.
    Some of these are really nasty.
    Main Gear
    Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    Once you get the name of the spyware/virus you can google it, and most of the time there will be an article or forum that has either know of a certain tool that can remove it, or instructions on how to remove it. From there you can decide if you want to try it or not.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
