Computer memory compatibility
edbert
Alright, so I am looking to add some memory to my computer. I already have 2GB Patriot Memory Xtreme PC 6400, DDR2 800 4-4-4-12 2.2V and look to upgrade it with 4GB Patriot Memory Xtreme DDR2 800 5-5-5-12 1.9V.
Current http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144
Upgrade http://www.newegg.com/Product/Product.aspx?Item=N82E16820220396
Which way do I need to adjust the timings and do I need to adjust the voltages as well(I know how to do all this, I am just unsure on which way to go)? I just want to know if these are close enough to work reliably and if so any adjustments that need to be made accordingly.
Thanks!
Thanks!
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
What motherboard/processor?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Your timings and voltage will auto adjust to the SPD settings of slowest memory in your system (which would be the 5-5-5 stuff). I always prefer to have matching memory throughout, but to each his own. If you install the 5-5-5-12 memory, the other memory will be performing slower than its spec'd.
I'm assuming you running a 64 bit operating system. Just checking. You will need that if you want to see all that memory.
Why not match things up better with you original memory's timings:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220269
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220293 -
Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819103773I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff. -
Thanks bill, I have a copy of XP Pro 64 that I can use before I make the switch to Windows 7 later this year. I just found a great deal on that memory new and thought I might jump on it if it would work.
Is it possible to bump the speed up to the 4-4-4 stuff without it causing any problems? I do have the option to adjust it in the BIOS settings, I just didn't know if it would cause any problems. And if I bump it up and do I need to adjust the voltage settings to the higher 2.2V to keep it stable or will that potentially burn up the memory?
Thanks again!I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff. -
From the couple of threads I seen regarding RAM and this motherboard, I wouldn't recommend mixing either."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks again!
If you have the options to bump the voltage and tighten the latencies and you feel comfy with that, it IS an option.
Honestly, i'd just put in the 4gig set and ditch the 2gig set if you're dead set on getting more memory on a budget.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks again!
I've never had much luck running memory at faster timings than the spec. It would probably be unstable.
It will either: not boot, or get flaky under heavy use. If you want to try it, I recommend running memtest (or similary) for at least 12 hours to see if its stable.
You can also check the newegg user reviews to see if anyone is able to get 4-4-4 timings. Worst case, just stick with the slower timings. You'd probably never notice a difference.
EDIT: I have to agree with Concealer. Ditch the 2x1GB set and get a fresh set of 2x2GB. You probably won't notice the difference between 4GB and 6GB unless you are doing heavy video work, and even that is questionable. -
You know, I wondered about that Billbill. I will probably do just that and sell off the 2GB's to recoup some of my cost. I just thought if it would work I would do it.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
