Ribbon Mahogany Sources
treitz3
The below image is what I would like to get for an audio project of mine. What I need is a 3/4" thick piece of Ribbon Mahogany that is 24" long and about 3" high. Anybody have a source?
Post edited by treitz3 on
I build solid body guitars from time to time. Or at least try to.
I have bought mahogany, cherry and swamp ash of eBay. Had a look there yet? If you needed some regular cherry or architectural grade mahogany. I could probably hook ya up with some. --Gary--
No, I try to stay away from E-bay like a two bit **** does communion.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
PM Sal Tom. He has some great wood contacts.
Thanks Joe. Will do.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I used to buy my hardwood from Paxtons until their OKC store was sold to Hogan Hardwoods. It was like being in a candy store.
You may have to have it shipped special order.
http://www.paxtonwood.com/ExoticHardwoods.aspx
