Computer Question
ken brydson
Anyone know how to burn a power point presentation to a DVD so you can watch it on a TV instead of just a computer? TIA
Post edited by ken brydson on
Not that I am aware of. Unless there is a save option for when you save the pp to have it be able to playback on a dvd player.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
ken brydson wrote: »Anyone know how to burn a power point presentation to a DVD so you can watch it on a TV instead of just a computer? TIA
Will let you save it as a vob file? Heres something...
http://www.allformp3.com/powerpoint-dvd-maker/Testing
Testing
Testing -
Thanks for the links guys. The first one worked but there are some sync issues with the music. Will try the 2nd one tonight to see if that helps. It's nothing major. My daughter made a really cute pp thing for her best friend for Christmas. She gave it to her on a CD but we were hoping to be able to put it on a DVD for her.
If you have a DVD recorder, it should be easy if you can just send it to the recorder via S-cable and sound via a 3.5 mm to r-l phono. I've done that with some videos from my camera (onto my laptop) to get them onto DVD."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
You might be able to do that but you will not have any control over it except the pause button.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
