Maximum interconnect lengths?
math wizard
math wizard Posts: 106
I just purchased an amplifier for my rear speakers. I would like to place it on the side of the room where the speakers are. To do this would require running two 35-45 ft interconnect cables from the AVR pre-out to the amplifier. Is this too long of a run? If the amplifier is placed near the AVR, shorter cables can be used, but it will require approx. 40 ft of speaker wire from the amp to the speakers. Is there any advantage/disadvantage to either senario?
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
Post edited by math wizard on
  • Pauly
    Pauly Posts: 4,519
    edited December 2009
    Better off running the long speaker wire run and i would use a 14g wire. The IC runs will cost you ALOT more.
    Good Luck
    Pauly
    Life without music would
  • CoolJazz
    CoolJazz Posts: 572
    Is there any advantage/disadvantage to either senario? Thanks
    Yes!
    With longer interconnects the biggest issue is the cable capacitance. The more the capacitance adds up, the more the high frequency roll off there is. It takes some level though before it even gets into the audible range. The issue involves how low the driving impedance is along with the loading value of the input along with the cable values.
    With longer speaker wires, the first and foremost issue is adding resistance which lowers the dampening factor. The loosens the tightness of the bass and causes the amplifier to have less "control" over the cone.
    Which way to go depends on not only the quality and parameters of the equipment but also your personal preferences for sonic quality.
    IMHO, the interconnect cable coming closer to exhibiting roll off is likely to be less of sonic effect than the speaker cable. Many feel differently than I do though! You are proposing a pretty darn long run! For rear channel, you're talking surround sound movie stuff and not music after all! Even if you get too much capacitance in the cable and have some slight rolloff, let's say above 15 or 16khz, that's tough to be very noticable and it's a very gentle sweeping roll off. While dampening factor control will have slight effects into the midband energy that would tend to have an audible effect on everything!
    That's some of the issues...
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    pitdogg2 Posts: 27,148
    CoolJazz wrote: »
    Yes!
    CoolJazz
    While i agree with the above I found that in some cases long in runs of component cables for instance some A/V equiptment have a hard pushing signal though a very long length. Plain old speaker cable say Dayton Audio 10ga. copper will handle long rungs just fine. I even use it myself for short runs just so all my wire is the same.
  • CoolJazz
    CoolJazz Posts: 572
    xcapri79 wrote: »
    +3 Keep your RCA interconnects as short as you can to minimize interference and low level signal loss.
    Can you explain this "low level signal loss" thing to me? What happens exactly? Does it just get lost and goes back the wrong direction in the wire...or fall off the wire behind the rack and get stuck in the dust bunnies? Where does it go? Should we sweep them up from time to time or something...??
    CoolJazz
  • quadzilla
    quadzilla Posts: 1,543
    What's hard to understand about it? In fact, your question would seem, at first glance, to be intentionally obtuse and argumentative. You have a very low level signal, so it's very sensitive to loss, and loss/distortions at that level will get amplified along with the rest of the signal when the power is finally applied. So unless you can afford very high end cables, both resistance and capacitance will be affecting the signal a fair amount. Even with high end ICs, runs that long are going to be subject to at least some loss. Also, it should be noted that the roll off starts down closer to 2 KHz, not above 16. Even if it didn't start until 16 KHz, that would still mean that your sacrificing all your higher order harmonics, whereas the few milliohms of resistance that a decent speaker cable adds over that distance will have much less effect than you'll find in most interconnects due to the greater capacitance in the dielectric used in common cable types, especially the budget cables. You're again more concerned with capacitance and the roll off of the high end, causing the sound to lose harmonics and sound dull and lifeless.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • CoolJazz
    CoolJazz Posts: 572
    Easy Zilla! It was a very light hearted question. Maybe I should have used a few smilies to illustrate... :p;)
    But I'd take even greater issue with your response. This low level loss thing is just about a none issue. It's a simple first order low pass filter that forms the long cabling issue. And the dielectric effects are probably more of an issue at higher levels than lower levels. Certainly, the roll off doesn't start at 2k!! I'm not even sure what your trying to say there.
    But overall, I was really trying to drive at some clarity for more of the newbie's benefit on this low level loss issue. It's an often bandied about term that just becomes thrown out there like you have to have enough overall signal level to push through the signal or something. You have to understand that "low level signals" are routed for great distances on copper wire! That's how phone calls used to be routed for thousands of miles. Oh...and network programming too that was wide bandwidth, high fidelity...not to mention network video in the days before satellite.
    CoolJazz
  • math wizard
    thanks to all who replied.
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
