Wich sub-woofer??
i want a sub that is good for rock and some rap. any ideas thanks
Post edited by Neale13 on
What is your budget? How big of a room? What do you currently have?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Look at SVS website. You cant go wrong !
Panamax M5100-EX HT Power conditioner
Yamaha RXV861 tuner
Carver TFM25 amp
Carver av-405 surround amp
Carver ct-17 Tuner
Sony BDP-S350 BluRay
Sony 222ES CD
Sony PS-LX520 Linear track Turntable
Panasonic 46" flatscreen
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Polk LSI 9 surrounds
Polk monitor 12 series II "old mains" -
Sunfire!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Check out SVS.
SVS, Epik, HSU--all good subs & value for $$$. A lot depends on your taste & budget.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Whats the differnce in sound between front or down firing? My mains are in my family room ,Can I put the sub in the den wich is just in the next room ? i would like to spend less than 600.00
there is no difference from a sound or performance perspective between front and down firing, down firing is safer as the driver is hidden (children and pets), the sub has to be next to the speakers to blend in, i have the DSW PRO 600 and it's great.
hope that this will be helpful. -
check out the Definitive Tech @ Magnolia Home theater in Best Buy. Bought one to add bass to my LSI 25's very happy and not very expensive.
Bets of luckOnkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area -
Ok I think im going to go with svs. My room is 20x26 with a kitchen on the other end and 10 ft ceiling height. i only listen to music. i have a pair of rtia9s with a rotel 1080. I want big bass with money to spend . Wich sub ?? Thanks so much
