D/A converter for casual listening?
dane_peterson
Hey guys,
I have my HTPC running HDMI out to my TV, and I'd like to have some small bookshelves connected to it. Unfortunately, the stereo receiver I currently have (HK3380) only has analog inputs, and my Panasonic only outputs via Optical.
Suggestions?
Suggestions?
Post edited by dane_peterson on
Zingo,
Appreciate you looking out, but unfortunately that's not gonna work for me.
Just FYI guys, I'll likely be adding a 2nd HDMI source this Holiday season, which means I'll ideally need an optical->analog solution. -
How much are you wanting to spend?
Do you only need 1 optical input on the DAC? In other words, will the TV send the audio through a single optical output, independent of HDMI source?
Another option could be to ditch the stereo receiver and get a new A/V receiver with HDMI inputs, so that an external DAC is not needed. This would also give you the flexibility to easily add a sub and/or expand to surround sound if you felt like it down the road.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
I like my PS Audio DAC III. The Benchmark DAC 1 gets a lot of praise.Speakers: SDA-1C (most all the goodies)
I'm looking to spend as little as possible. And yes, I'd only need a single optical input.
This is all for my bedroom, and surround won't be an option. I've juggled the idea many times, but there's just no way my wife would allow speakers to sit on our nightstands or something.
My current receiver does have a sub out, which I may consider adding down the road. But this is going to be VERY budget. When I get around to doing a nice 5.1 setup, it will be more dedicated in the basement. I just want better audio than the built-in speakers. I'm currently modding a pair of the Insignia bookshelves for a friend, so if they turn out well, I might go that direction. No more than a couple hundred for the speakers--therefore a several hundred dollar DAC would be silly. I just didn't know if there might be any really cheap ones out there. -
Optical in and RCA analog out for $214: http://www.pacificvalve.us/LITEDACAH.html
Since you are using an HTPC, wouldn't a USB DAC also work for you? -
USB will work, until I add a Bluray player and have another HDMI going to the TV. Though I suppose I could run analog out from the BD player to the amp...
Here are a couple of the lowest cost DACs I've seen. I would imagine they would be adequate for TV viewing with inexpensive bookshelf speakers.
http://www.audio-magus.com/Super_Pro_DAC707SE_USB_p/109401.htm
http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/digital-to-analog-converter-979r/prod979R.html#
Up from there, in the $200-300 range, I would look at the Beresford, offerings from Pacific Valve, Keces, Valab, Musical Fidelity V-DAC, or something used.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
