PSWi225 with Surround Bar 360
I just purchased a Surround Bar 360 which is great. I am considering the PSWi225. How do I connect the PSWi225 to work with the 360 DVD/Controller box? Thanks.
Post edited by asilverwood on
  • dorokusai
    dorokusai Posts: 25,576
    edited December 2009
    Use the Sub Output on the back of the SB360 box.
  • asilverwood
    asilverwood Posts: 8
    Thanks for the quick reply. I have the 360 controller wired in my basement, while the sound bar is on the first floor beneath the t.v. Should the RF receiver for the PSWi225 be able to transmit to the subwoofer on the 1st floor without any problem?
  • eclimax13
    eclimax13 Posts: 168
    should not be a problem
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • asilverwood
    eclimax13- I see you have a PSWi225. Do you highly recommend it?
  • eclimax13
    i wrote a review...a couple of posts down
