Tube testers
treitz3
treitz3 Posts: 20,119
edited December 2009 in 2 Channel Audio
Hello folks. What this thread hopefully will contain is nothing but information on what reliable tube testers there are out there.
What I am looking for is something that is a trusted, well established and reliable tube tester that folks can believe in. I realize that may be a tall order, but I'm willing to learn. If you have any experience or knowledge [even if it's just research], please let me know what you know.
In other words, allow me to pluck your brains.
I'd like to know, not only for my own rig...but for tubes that I end up trying that don't quite cut it in my rig. You know...system synergy and all that...? Those same tubes may be the cat's meow in another Polkies rig. I'd just like to be sure I would be reselling a decent tube worthy of a purchase. ;)
School is in session. Teach me, if you will.
Post edited by treitz3 on
  • thsmith
    thsmith Posts: 6,082
    Tom, Hopefully you have read this.
    http://www.alltubetesters.com/articles/tester_guide.htm
    I went with a Sencore 142 which has already paid for it self by identifing a tube with a short.
    WHen I was on my quest I received a recomendation for Sencore and in my reading it fit what I needed.
    SOrry that about I have on the subject.
    mhardy6647 Posts: 35,232
    For emission-type testers, the Sencore Mighty-Mites are fine. I have my father's :-)
    If you want to be able to test transcondance (e.g., to match tubes), invest in a refurbished and calibrated Hickok (e.g., TV-7 or one of its relatives).
  • doctor r
    doctor r Posts: 837
    Second on the Hickok. You will get more information compared to just an emmission tester as mrh indicated. I am also biased since my father worked for Hickok and helped integrate the cardmatic reader into the Hickok 123. Presently using the Navy version (USM-118) cardmatic myself.
    Rick
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • skrol
    skrol Posts: 3,464
    My dad has and still uses a Hickok 800.
    Stan
    Main 2ch:
    HT:
    Other stuff:
