Receiver or Amp
mjg
mjg Posts: 86
edited December 2009 in Electronics
I am looking to buy new speakers, and have decided on Polk LSI15's. (also looking at B&W CM7) After doing alot of research it seems I need a really powerfull receiver, or at least to upgrade to a receiver with pre-amp outputs, and an amp. My current receiver does not have pre-amp outputs. I am interested in staying with a 5:1 suround system, and dont know if that means that i need a five chanel amp or not. Found Marantz SR 5004 for $650.00 shipped on ebay. Good deal? Any and all help would be appreciated.
MJG
Post edited by mjg on
  • bluecomet
    bluecomet Posts: 1,118
    Since you don't have a receiver with pre outs you will have to get one or a pre amp made for HT. You will then have to buy a quality amp that can handle 4 ohms to drive any Lsi speakers. You should also look into an amp that can push at least 200 watts at 4 ohms to make the Lsi 15's sing. You are going to have to invest a few dollars to set up the Lsi system but it is worth it in the long run. You will need at least the Lsi center speaker to have the front of the system sonically match which is important. I am sure a few will chime in as to what there favorite amps and receivers are. I currently use a Carver 3 speaker amp to power my mains and fronts, with an Emotiva amp to power the rest of my 7.1 system. I am pleased with it. Hope this helps.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
    nooshinjohn Posts: 25,894
    Amp....
    tonyb Posts: 33,069
    Both,don't try and push the LSI's with a receiver alone. You need a receiver with pre outs and an amp. Or a different speaker selection.
  • mjg
    mjg Posts: 86
    Any suggestions on equipment? Keep in mind that I dont need to go 7:1 I am open to used or refurb, I just dont know what to look for yet. To much stuff, to many options, limited amount of money.
  • Hawkeye
    Hawkeye Posts: 1,313
    Purchase an AVR that has preouts and a minimum of bells and whistles you can live with. AVR's become obsolete as soon as you install them. Invest as much cash as you can in a high power (watts/current) amplifier. They don't go obsolete and amplification is the foundation of any system.
    Recommendation: For an amp, A B&K 5 channel amp (7250)should give you more than entry level sonics and rock solid dependability.
    I have a HK 254 as my AVR with the above amp.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • mjg
    mjg Posts: 86
    could I use a b&k reference 2220 for the fronts, and let the receiver run the rears and center? I am having a hard time trying to figure out what to get. Spent about 2 hours looking through audiogon tonight. No b&k 7250. Any other sugestions
  • cfrizz
    cfrizz Posts: 13,415
    If you intend to run a complete LSI set of speakers, then you will need a 5 channel amp to push them with.
    Welcome to Club Polk.
  • mjg
    mjg Posts: 86
    Thanks,
    I am just upgrading the two fronts to lsi now. Would this be easier if I went with the B&W's or maybe the rti a7.
    I'm pretty sure the Marantz 5000 series has pre-outs--you should check their site they have pics...Therefore, for now...all you need is a good 2 channel power amp that will handle the LSis...you can get those used starting from around 250 to 500. I'd stick with the LSIs and save up for the amp...it's really not horribly expensive.
    cnh
  • Hawkeye
    mjg wrote: »
    Wow! I went down this same road. I started with the 7250 and added a 2220 for the front mains and used the 7250 to get a 7.2 rig. If you obtain a 2220 for the fronts, you'll be pleasantly surprised! Let the AVR run the rest and add to it as funds allow.
    If you like the sound of the LSI, do what is necessary, not what is easier. You'll have that thought in the back of your mind, "wonder what this would have sounded like if I bought the speakers I REALLY wanted"
    Gordon
    2 Channel -
  • mjg
    mjg Posts: 86
    I found a good buy(i think?) on a Rotel 981 for $350.00. My question now is how do you figure WPC @ 4 ohms when specs are given @ 8 ohms? Can you just figure it at twice the rated WPC as I have seen in some specs, or is there another way. The rotel is rated at 130 @ 8 ohms. I guess what i need to know is will this amp(very well reviewed) drive LSI 15's well?
    Thanks for any help MJG
  • cfrizz
    It will drive them, but I don't think you will be getting them to operate to their full potential.
    LSI's sound better with the more power you feed them. You should be looking at 200wpc @ 8ohms, that will give you almost 300wpc @ 4ohms with most amps.
  • mjg
    mjg Posts: 86
    I will keep looking. thanks.
  • Jetmaker737
    Jetmaker737 Posts: 1,111
    You should take some time to properly research some amps. If you're on a budget you can pick up an Adcom or older Parasound amp that can drive the LSi's.
    Look here for reviews:
    http://www.audioreview.com/cat/amplification/amplifiers/PLS_1583crx.aspx
  • mjg
    mjg Posts: 86
    Thanks,
    I have been looking on ebay, and on audiogon. Here is the list of what has stood out from the rest. B&K reference 2220(still pricey for the age), Carver M 500, Carver TFM35x, Carver TFM 25. I read revues on about 50 different amps. The one parasound I found in my price range got bad revue. I also hear nothing good about Adcom. Any input on these or any others would be greatly appreciated. Thanks, Maurice
  • Jetmaker737
    mjg wrote: »
    Thanks,
    Interesting. I've never had one but seems most the folks here at CP who've had them have good things to say.
    You should search these forums for the amp models your interested in.
    FYI, there's a TFM-24 in the For Sale section:
    http://www.polkaudio.com/forums/showthread.php?t=93452
  • mjg
    mjg Posts: 86
    Adcom GFA 555 seems to be a classic that gets good revues. I will check out the TFM-24 on the classifieds here. Anyone use this to power LSI 15's?
    Thanks, Maurice
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Look at
    outlaw
    Adcom
    for amps but as said above you need a preamp or a receiver with pre outs.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • mjg
    mjg Posts: 86
    Thanks to every one who gave me advice, and helped to educate me. I ordered the LSI15's (back ordered till mid Jan.) and am picking up a nice amp (from some one here) to power them. Now I need to find a 5:1 receiver with pre amp outs, and HDMI if possable. Any and all suggestions and advice would be appreciated.
    Thanks, Maurice
    mjg wrote: »
    MJG
    You had mentioned the sr-5004 Marantz. That has pre-outs, HDMI, etc. and would work for you plus that's a pretty good price and they come with a 3 year warranty..
    cnh
    Yamaha RX-v861 or 863 would fit the bill as well
  • coolsax
    coolsax Posts: 1,826
    the Yamaha RX-V665 also fits the bill with Pre-Outs and has plenty of HDMI inputs.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Jetmaker737
    Make sure you get an AVR that has a Direct or Pure Audio mode that bypasses the digital signal processor for 2 channel listening.
  • mjg
    mjg Posts: 86
    Thanks, Thanks, and Thanks. I am on a new quest. Will let you know how I make out. If anyone Knows if the above mentioned AVR's have the "direct or pure audio mode" please let me know.
    Thanks, Maurice
  • mjg
    mjg Posts: 86
    All the listed AVR's are 7.1 Are there any 5.1 that might be a little less $?
    Thanks, Maurice
  • Jetmaker737
    mjg wrote: »
    Maurice,
    You can usually get the user manuals at the manufacturer web site. It's a good way to learn about your prospective purchases. :cool:
    Jet
  • cfrizz
    mjg wrote: »
    Thanks, Maurice
    Unless you go used, you will be hard pressed to find a 5.1 receiver. 7.1 has been the standard for quite a few years.
  • bigaudiofanatic
    I know it is a shot in the dark but, look around on ebay on craigs list and post a wanted add on here. For a pioneer elite receiver I picked mine up for 300 but I lucked out big time. I have seen them on ebay that go as low as that. I know that you will probably want a amp later to give the polks some more power.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • mjg
    mjg Posts: 86
    Thanks, I will look for the Pioneer. I found a Yamaha rx-v863 and am waiting to hear back from the guy. I am in the process of buying an amp now. The receiver is the last piece for now!!
  • DMara
    DMara Posts: 1,434
    tonyb wrote: »
    I 2nd this post! Take care of your lsi15's with an amp, do not plug them directly to the receiver!
    I tried to power it with my Denon AVR-2808ci previously. However adding an Emo XPA-5 did help my lsi15's as well as lsi/FX's and lsiC to perform way way better :)
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
