MIT Shotgun S2's on their way!
pearsall001
After reading all the fan fare & hi-regards on the merits of MIT cables from fellow members (I do take note & value the opinions found here)...I pulled the trigger & bought the 10' pair of Shotgun S2's & it's matching S2 IC from sir_lagzalot (it very nice doing business with him by the way). They should be here in a day or two then I'll get everything put into place & settle in for an extended listening period. I'll be using the S2 IC from my source to the pre as recommended. From what I've been told the effect of MIT cables is compounded as you add more matching cables from the same line.
I'm sure my next move will be to pick up another S2 IC to use between my amp & pre. I'll follow up in a few weeks with my findings. If all is true, I'm sure I'll be very pleased. Stay tuned.
Post edited by pearsall001 on
Good work fellow Jersey guy. Like someone else says around here, they should be the last cables you need to buy.
Congrats Phil.
We shall see fellow Jerseyite!!!"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Phil, once you get those in your system, we'll never hear from you again. You won't be able to drag yourself away from the sweet spot! I love the MIT cables, got them everywhere.Carl
They are awsome cables for sure. Enjoy!Vinyl, the final frontier...
You have them everywhere!!! I'm starting off slow & will proceed at a much slower pace. I've got quite a few cables to say the least."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
pearsall001 wrote: »You have them everywhere!!!
It took me a good while to get there. Speaker cables, pre-amp to amp, source to pre-amp is the way to start.Carl -
I told him the opposite!
At first I thought the speaker cables made the most difference but after swapping out with various different IC's I'm not sure. Both make a pretty big difference.
I had MIT speaker cables long before I bought the ICs. When I got the ICs, I started with my sources. With the turntable I first went from TT to phono pre then from phono pre to my integrated amp.
hearingimpared wrote: »I told him the opposite!
Joe, I also emailed Joe Abrams & asked him where to start with the one S2 IC. Here's a copy of his response:
Dear Phil,
Thanks for your kind words. I'm always happy to help members of the Polk Audio Forum.
When all your interconnects are not on the same performance level, I always recommend that the BEST cable go furthest UPSTREAM in your system. Any loss or distortion that occurs at the source can't be recovered or fixed downstream. In this case, place the S2 between source and preamp.
Hope this helps.
Happy Holidays!
ATB,
Joe"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Congrats Phil. I am sure you will be impressed.Michael
NORTH of 60° -
pearsall001 wrote: »Joe, I also emailed Joe Abrams & asked him where to start with the one S2 IC. Here's a copy of his response:
Dear Phil,
Hope this helps.
Happy Holidays!
ATB,
Joe
Never doubt my ear son.:D -
COngrats and Joe is great guy to buy from.Speakers: SDA-1C (most all the goodies)
Yeah he is. I bought 5 pairs of S3s ICs from him. One had a problem and he took care of it pronto. -
pearsall001 wrote: »Which one???
The left!:D;) -
My post was in no particular order. Both Joe's are correct! That's how I started. The speaker cables were actually my last purchase. MITs are the way to go. There are other good interconnects obviously, but the MITs made the best improvement to my ear.Carl -
I'd be totally interested in your findings. I've heard so many good things about these cables. When I'm ready to upgrade cables- MIT's are next for sure.
The cables came late this afternoon...in the midst of a 26" blizzard! Kudos's to the USPS!!! I wasn't expecting any mail delivery today with the weather. My carrier even wrapped the box in plastic & made sure we were home for delivery. He's a great mail man that services us all year long. I take good care of him at Christmas for his exceptional service."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Are they hooked up yet?
hearingimpared wrote: »Are they hooked up yet?
All done (S2 IC will be here Mon or Tues). Man these things are a bear. Off to bed now, I'm beat from wrestling with this damn snow!! Till tomorrow
Sounding good!
Can you describe what you are hearing?
hearingimpared wrote: »Can you describe what you are hearing?
Right now...Andrea Bocelli, my Christmas!! Awesome!!!
My initial impressions are that the MIT's really bring out the full spectrum of music. I do a lot of low volumn listening & the detail is incredible. I want to settle in with them for a little longer, especially once the S2 IC arrives & is added to the mix. But for now, I'm very, very pleased! More to follow."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
See!
Don't forget to give the I/C's some time to break in."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
MIT's are a very balanced cable and really have great micro dynamics. I made the switch a couple years ago and I doubt I'll ever buy another brand cable. Many think MIT's "color" the sound, I don't find that at all...........if anything they tend to show you what other cables miss. Many take the clarity and additional spectrum of sound as being colored but it's revealing what was there all the time.
Wait until you get some MIT speaker cables
P.s. My bad I see the S2's are speaker cables..................NM
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I've done a lot of experimenting with the IC part of the equation and I think MIT is correct when they say matching their cables with their same series IC's is the key to realizing the best synergy.
You are also smart to withhold judgment until you had a chance to get to know the cables for for a week or two.
I was just adding up my S2 cables/IC's and realize I have 160' of this wonderful stuff in my listening room! :eek:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
You're right. Mixing Shotgun and AVt in the same rig will produce some odd results.inspiredsports wrote: »I've done a lot of experimenting with the IC part of the equation and I think MIT is correct when they say matching their cables with their same series IC's is the key to realizing the best synergy."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I am definetely taking my time & don't want to rush the listening critique. I have noticed a few attributes but will hold off till the S2 IC arrives & is added to the mix. But just having the S2 speaker cables at the moment, I'm impressed. I'm getting a good feeling of what others have said about MIT."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
