I wish polk made some better satelite speakers
1fastz28
1fastz28 Posts: 122
edited December 2009 in Speakers
the best set they have is the rm20 and my store doesn't carry them anymore, the rm85/95 series sounds average, maybe i'm just spoiled with my rti setup, but i wish they had a better satelite setup, anyone else agree?
setup
Panasonic 46pz85
Polk RTi A9's
Polk CSi A6
FXi A6's
Energy s12.3 sub
Denon 3808ci
Pioneer elite dv-79
Monster 1850
Denon dp500m w/ grado green
PS3,XBOX 360, NES
Post edited by 1fastz28 on
  • rallyshark
    rallyshark Posts: 417
    FYI, you can still get the rm20 from Polk Direct on ebay(polk's ebay store). It's not just Polk, it's pretty much everyone. There's only so much that can be done on speakers that small. Unfortunately, there is no replacement for displacement:) The VM series is really nice for the size, but expensive. I'm in the same boat really. I only have space for satellites. As my sig states, I'm using a combo of OMW5s and an RM20 5pack. It actually works quite well for HT, especially if you have the means to made plenty of adjustments:) I don't use them often for music though, that's when the 11Ts get to play...
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
    Any of you guys ever consider useing the Atriums as sats ? They maybe a tad bigger than the RM's,but smaller than a bookie. I would think the Atrium 55,or 60 would make a damn good sat. speaker.
  • Knucklehead
    Knucklehead Posts: 3,602
    That is what I was thinking Tony, I can tell you from first hand experience the new A4's would serve that purpose very well.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
