Get Adcom Gtp500 fixed?
ozzy21236
ozzy21236 Posts: 100
edited December 2009 in Electronics
I'm debating having my gtp500 fixed.I picked it up in a package deal along with a Gfa545 . It has issues with the tuner and tuned bleed over when another source is selected. The only other pre I have is an adcom gfp555mkll.
My question the is : is this pre worth $150 investment (price includes shipping) to get fixed? I plan to use it on a second system done the road. Has anyone ever used ebcelectronics out of New Jersey to have any gear fixed?
I know it isn't a higher end pre but I'd like to have a remote for now with minimal investment.
Russ
Technics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2
Post edited by ozzy21236 on
  • ozzy21236
    No one has an opinion on this? Any feedback appreciated.
    Russ
  • Neskahi
    Neskahi Posts: 297
    vgernet.net/bks0731
    If this link works it contains some possibly useful info.
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    Link no work I guess. I had to type it in but it's active.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • concealer404
    concealer404 Posts: 7,440
    The tuner issue is pretty common on the GTP-series.
    You'll spend at least $150 to get the same performance as that unit i would imagine, so $150 to keep it around instead of trashing it and getting something else on the same performance level seems relatively reasonable.
    Do you like it enough to pay $150 to fix it?
  • ozzy21236
    I listened to it alittle and I think it is as good or close to the GFP-555mkll Im using, so yes I think its worth it to get it fixed. I was just hoping some owners or previous owners could relate their experiences. Mainly for now ,I want the remote capability that my current pre doesnt offer.
  • fbm211
    fbm211 Posts: 1,488
    I used that repair place in jersey to get my monoblocks fixed.He did a great job and I havent had any problems in the 18 months or so since the repair.
    Is it paul you contacted.I highly recomend EBC.And Ben might be able to fix it too.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
