Bad case of IR on my new plasma
rdb2001
rdb2001 Posts: 791
edited December 2009 in Electronics
My plasma is about a month old and I have done all the things that were said to be good for it in the first 200 hrs. Turn brighness contrast down, use those color frames on the sd card slot, etc. Well I played a 30 min game on NCAA and now I have a bad case of IR. It has been there for about 12 hrs and it is really bothering me. What do i do.
Post edited by rdb2001 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    Did you try watching tv ( full screen) to see if it goes away? Usually after watching tv 30 minutes or so it should go away. What kind of plasma?
    Mine has about 200 hours on it and I've played madden for hours without any IR. Some plasma's are better than other when dealing with IR and burn in.
  • rdb2001
    rdb2001 Posts: 791
    yeah but i dont think it was 30 mins, guess i will try it again. I cant see it when viewing, tvs, blus or anything, just on a blank input and up very close to the tv.
  • Knucklehead
    Knucklehead Posts: 3,602
    Yep, Leroy is right first time it happened to me I was like, oh hell no!
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    billbillw Posts: 7,798
    If you can find something that has a full white screen, put that on for about 30 seconds. It should wipe any IR. Some TVs have a built in feature for this.
    If you can't find any programing like that, you could make a 1920x1080 image of pure white using a photo editing program. Put it on SD card and play for 30 secs.
    OK, I just made one for you and attached it here.
  • rdb2001
    rdb2001 Posts: 791
    I wonder other thana photo editing software, where i could find a pure white image.
  • rdb2001
    rdb2001 Posts: 791
    billbillw wrote: »
    thanks
  • leroyjr1
    Just rerun the break in images for 10 minutes or so.
