Martin Logan Grotto i subwoofer
suprafantx
Up for grap is Martin Logan Grotto i subwoofer. It used less than 4 months and I only use it about 2 hours a week. It is excellent sub for music. I have it set up in my guest room so I would say it is not even break in yet. I could not find any hair line scratch or ding. Cosmeticcally I rate it 9.5/10 due to box opened and hooked up. I still have the box but will not ship. Local pick up only (Houston,TX area).
I will take 800 for it.
Will post pix later.
Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1.
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
Post edited by suprafantx on
Here is the pixLiving room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
Room treatment: GIK Room Kit #1. -
Here is the specs
Frequency Response
22–120 Hz ±3dB; Anechoic through LFE effects input
Low Pass Filter Frequency
30, 35, 45, 55, 65, 80Hz
High Pass Filter Frequency
70Hz
Low Frequency Transducer
10" (25.4cm) high excursion, aluminum cone with extended throw drive assembly, sealed non-resonant asymmetrical chamber format
Amplifier
300W (at less than 0.5% THD)
900W (peak)
Impedance
Line level RCA: 20,000 Ohms
Controls
±10dB at 25Hz
Inputs
Left/Right RCA Line Level, RCA LFE, Speaker Level
Power Draw
Max: 250 Watts
Idle: 15 Watts
Standby: 10 Watts
Weight
51 lbs. (23.2 kg)
Dimensions
18.6" × 15.2" × 13.8"
(47.3cm × 38.6cm × 35cm)Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
