Looking for a Peerless as shown
geppy1
Looking for a Peerless as shown. Gold back with flats on the housing and marked 5514____ Around 1981 for an RTA 12B Thanks,keith
Post edited by geppy1 on
There were a couple of vintage peerless tweeter on EBay, you might check out. I think they were from Mon10a's. Course it is Ebay, so buyer beware. Good luck.
that picture is pretty blurry... you can probably get a sharper picture if your step back from the object and then use your cameras zoom to get in close. most cameras have a minimum distance required to focus on an object so steping back and using the zoom is the simple way to making sharp close-ups even with the most basic of cameras.
also, this archive might help you identify your tweeter as well as find a suitable replacement...
http://www.tymphany.com/archives/2
