Monitor 10A's or B's ?
mikey-polk
mikey-polk Posts: 83
edited December 2009 in Vintage Speakers
This pic shows some 10B's it says.
My 10A's appear to have the same tweeter, altho they are mounted upside down to these, the wires go top to middle, not bottom to middle.
http://fredericksburg.craigslist.org/ele/1475245299.html
Post edited by mikey-polk on
  • kawizx9r
    kawizx9r Posts: 5,150
    The Polk's posted there on CL have the tweeters positioned properly. If yours don't look like that (assuming you have the same tweeter) then yours are simply upside down.
    Another variation is where the leads coming from the tweeter go straight out to the sides.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • ben62670
    ben62670 Posts: 15,969
    Way too expensive for one, and I am not sure if ant 10's left with the SL1000 tweeter, but they appear to be them.
    Ben
  • anton.chigurh
    anton.chigurh Posts: 239
    ben62670 wrote: »
    I agree....looks like mismatched tweeters. Funny since the ad says they "look and sound as they did new"
  • geppy1
    geppy1 Posts: 3,076
    Looks like one SL1000 and one US made Peerless. I am guessing As as the SL1000 was the replacement if one blew a Peerless. I have compared the two tweeters extensivly and found the the 1000 to have wider dispersion and be more transparent and quicker however in the wrong system it can come off as bright. The US made peerless is very warm to my ears and full. keith
  • ben62670
    The SL2000 wasn't really a replacement, but was used in a hand full of SDA's and monitors. Because they will drop in the hole doesn't make them work properly. The XO for peerless tweets are different than other XO's.
    Ben
    Ben
  • comfortablycurt
    comfortablycurt Posts: 6,745
    geppy1 wrote: »
    The SL1000 isn't a replacement for the Peerless tweets. They used different values in the HF circuit of the XO.
    That looks like one SL1000 and one Peerless tweeter. The Peerless is probably the original tweeter though. At $280...it's a bit overpriced IMO. Especially when you factor in the extra $50-60 to get the tweeters matching.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • geppy1
    geppy1 Posts: 3,076
    Values aside I can tell you of several people who had Peerless tweeters go out and were given SL1000s by actual Polk Dealers as the "upgrade". That would also help explain why one sees so many o 10s and 10As with SL1000s
    The RTA 12B is a very good example Between 1981 and 1984 the crossovers and their values stayed the same (other then cap manufactures and type) yet Polk used 3 or maybe 4 different tweeters on them and NONE of them sounds the same. Go figure. keith
  • woodsman10b
    woodsman10b Posts: 408
    They both look like SL1000's to me, I think its the bad camera angle and lighting. The one on the right does look darker but it would look really dark if it were a peerless. Either way they are asking way to much!
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
  • ANWKLO
    ANWKLO Posts: 173
    geppy1 wrote: »
    My bad Peerless were replaced by SL1000 in Monitor 5. SL1000 were bought from local Polkaudio dealer. SL1000 sounds more open air than Peerless. Peerless sounds smoother than SL1000:)
  • agreece09
    agreece09 Posts: 8
    I was in the same boat, except didnt want monitor 50s. Im still probably gonna get the t90es though. But sucks to know you missed a great deal. I personally think they are gonna only get more expensive but they dont do any 30 day price guarantees so purchase at your own risk.
  • kcoc321
    kcoc321 Posts: 1,788
    are these going on sale anytime soon?
    i missed the 50s when they were like 50-60 bucks from frys or neweggi cant remember. Any timetable as to how often ANY of the speakers go on sale?
    i need tower speakers and know the monitor & europeans are the same thing, different name. any help would be appreciated
    These are VINTAGE MONITORS. See the pictures?
    Whole different ball of wax.
  • kcoc321
    Whole different ball of wax. They do sell for about the same price, depending on condition :)
