XLR Jumpers
Jetmaker737
Jetmaker737 Posts: 1,118
I bought an amp whose owner's manual states that if running RCA inputs to the amp, then pins 1 and 3 on the XLR inputs should be connected via jumpers.
How critical is this? I don't have the jumper pins. Is there a good substitute?
Post edited by Jetmaker737 on
  • megasat16
    megasat16 Posts: 3,521
    edited December 2009
    Yes, you need to use these jumpers pins if you use RCA connection instead of XLR connections. It's very critical for the amp to work normally but very easy to make one.
    Just find some solid core electrical 10AWG wire and cut about an inch. Then, completely strip off the outer plastics layer to expose the bare metals and create a U shaped bend but make sure it'll fit between pin 1 and pin 3 of the XLR connectors. If an inch is not long enough, cut off another length of wire a little longer this time.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • ben62670
    ben62670 Posts: 15,969
    Run down to rat shack and buy XLR plugs. short pins 1 and 3 together.
    Ben
  • Jetmaker737
    Gentlemen, thank you for the advice.
    Jet
    heiney9 Posts: 25,440
    You must short them for the proper gain.
    You can buy the pins here but there is a min. order charge. Doesn't hurt to have some extras
    http://www.dedicatedaudio.com/inc/sdetail/5158
    I bought from them and they are all std size and very nice.
  • CoolJazz
    CoolJazz Posts: 572
    I'm not so sure about it effecting gain (though maybe there is an architecture that could be). But it does raise the possibility for noise. The unloaded input can open the door for noise which could be greatly amplified! Basically an antenna just waiting....
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    CoolJazz wrote: »
    CoolJazz
    IF you're not going to use the balanced connection the pins need to be shorted because IT DOES affect the gain on almost all truely balanced circuits, and not having them shorted in some cases CAN increase the noise floor because of the low gain.
    To the OP read the owners manual and if it states the pins need to be in place then I would follow that recommendation.
    Most of the time it's just the inputs that need to be shorted not the outputs. I had a balanced DAC at one point and the output didn't need to be shorted but the balanced input on my pre needed to be shorted if I was using the single ended RCA's instead of the balanced connection. Same with my amp, I use the single ended RCA because I think it sounds better and the shorting pins MUST be in place in order to get the proper (intended) gain.
  • Jetmaker737
    The amp is an Aragon 8008 Mk II and the manual does state to jump the pins.
    Thank you for the link H9!
  • BlueFox
    BlueFox Posts: 15,251
    Was this a new amp? I would expect a new amp to include these jumpers, and if they expect a customer to buy jumpers in order to use RCA cables I would like to know so I can avoid their products in the future.
    BlueFox wrote: »
    I doubt it was new since Aragon is no longer in business. Well, they sort of are because a group of investors has bought the name in hopes of reviving the good 'ole days.
    Most people lose those tiny little jumpers and I'm sure they were included in the original purchase.
    If you buy a used Pass amp, just email Pass Labs and they will send you new jumpers for free since they are easily lost if the former owner isn't careful.
  • Jetmaker737
    BlueFox wrote: »
    H9 is correct. The amp is used, and Aragon is no more :(
    However, it's a beautiful piece and I can't wait to try it!
