Eliminating hum from ground loops
Bubinga99
Bubinga99 Posts: 283
edited December 2009 in Electronics
I've got some very audible hum, looks like this at the speaker inputs:
which seems to be due to the audio from my set top box being brought over to my pre-amp, with the loop being completed by a recent new piece of gear (also plugged into a line input on the preamp) with a 3-prong plug.
Anyone ever use one of these Hum-X things:
http://ebtechaudio.com/humxdes.html
and how well did it work out?
They aren't exactly cheap, but if it works...
Post edited by Bubinga99 on
  • Serendipity
    Serendipity Posts: 6,975
    Not sure, but...
    What kind of oscilloscope is that? Agilent/HP?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • kuntasensei
    kuntasensei Posts: 3,263
    When you say "set top box", what do you mean? I ask because I had a ground loop issue with my cable DVR, which caused faint rolling lines to my projector when I was running component video. Had to throw an isolator on the cable line to fix it.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • mmadden28
    mmadden28 Posts: 4,283
    Disconnect the Cable line (coax) going to the set-top box and see if that eliminates the hum. It's one of the most common causes of a Ground Loop hum further down the audio chain.
    ____________________
    Pool: Atrium 60's/45's
  • Serendipity
    Parts Express used to have these cable isolators for sale, they work well but slightly attenuate the signal.
  • Bubinga99
    Coaxial isolator might work too, but has insertion loss and other possible signal quality issues to consider in picking the right one. Guitar Center carries the Hum-x and there's a store near me. I called and they said I can return it if it doesn't work. Reason I think that might work is I temporarily replaced the 3-prong plug with a 2-prong and no more hum.
    Scope is an older Tektronix 400MHz 4-channel.
    Set top box is just a basic digital cable tuner/demod. RG-6 in, baseband video and audio out. No other functions like DVR. Cable modem is separate.
    treitz3 Posts: 20,119
    Never mind. I'm tired. Goin' to bed now. I've got a date with the pillow.
    Carry on..........
  • steveinaz
    steveinaz Posts: 19,546
    If it turns out to be your box, run audio via Toslink if possible, this will break the loop.
  • Bubinga99
    Steve, my preamp is from the Mesozoic era and only has unbalanced RCA connections ;)
    The Hum-X...works.
  • erniejade
    erniejade Posts: 6,321
    I use the humX on my DJ gear when I do Karaoke. Everytime I plug in a LCD I get a hum but the HumX stopped it. I also have had different venues where no matter what I did I would get a buz and again HumX helped me.
  • thsmith
    thsmith Posts: 6,082
    I need to try one of these. My Direct TV HD DVR is causing my problem but I still have it when I use toslink cable but do not if I remove the sat coax from the DVR.
    It would be nice to be able to put the ground pins back in on my PS audio power cables.
  • zingo
    zingo Posts: 11,258
    I would also suggest to anyone to try Toslink when connecting video or noisy equipment. I am currently running Toslink from my PC to my DAC and it seems to have cut some background noise.
    Keep in mind that the HumX can only handle 6 amps.
