receiver
royalty
I recently made a post saying that I was going to get rid of my onkyo receiver because I wanted something less bright. I was recommended an HK possibly the 354. I have found a good price on Pioneer elite possibly an VSX-92TXH or an Sc-05. Would these fit my needs like an HK would?
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Post edited by royalty on
Absolutely! I would definitely recommend the SC-05 in particular over the HK.
how about the other one? I have heard some good things. I really dont think I need all the power of the ICE amps on the 05. I have two separate ampsHOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Infinity 6032CF's all around -
Based on what I have seen in the HK Forum. I would stay away from the 354 or 254.KP
Receiver: HK 354
Amp: Adcom GFA 555
Front: Polk Monitor 70
Center: CS2
Sub: PSW 125
Surrounds: Old Yammi's
CDP/DVDP: Sony DVP-NC600
Blue Ray: Samsung BD-D5700
TV: Sony 50" SXRD -
I have looked into these firmware issues that you have most likely are talking about. Supposedly if I buy a refurbished 354 from HK directly they have fixed all of their problems and is under a original manufacturers warranty.
Both pioneers will cost me a little more than the 354 and I am wondering if it would be a good idea to spend a little more?HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
I think either of them will be a step up from the HK.
Thanks for the help!HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
I am hoping that my returned unit will have the latest firmware upgrade. I still am surprised by the number of issues these units have. My biggest surprise (besides going into protect mode) was that turning off the video processing on the setup screen, doesn't really turn it off. I have found the video processing less than stellar and have resorted to a direct hookup from source to TV. I will say though that musically, the HK is outstanding.KP
Receiver: HK 354
Amp: Adcom GFA 555
Center: CS2
Sub: PSW 125
TV: Sony 50" SXRD -
Older ATM's that I service use this type of comms to record data capture, I would try lowering your baud rate and possibly changing to parity. This is a relatively slow way of data transfer, I bet if you lower the baud rate it would clear up the character confusion. I cant remember but in binary their are several letters that are very close in the way they are presented.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
