Rm510?
I can't find any support information on the RM510 surround speaker system. I am considering purchasing this to go with an Onkyo TX-SR607. Is this a discontinued model? Is it worth purchasing (currently on special for $399) or is another system, such as the RM705, comparable or better?
Post edited by meberman on
I believe you were referring to the RM10 5 pack, or the RM 75? Go to polk direct ebay store, you will beat those prices easily.
Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
I was wondering the same thing. At Newegg.com it is listed as the RM510. Other places such as Amazon and the Polk site have the RM10 5-pack that you've mentioned. I don't know if they are the same thing.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290174&Tpk=rm510 -
The RM510 appears to be the current generation RM85 with PWS110 (or very similar) sub, a step up from RM705 or RM75, IMHO.
