PSW505 or Klipsch SW-450
Thinking about swapping out my PSW110. The PSW505 is going for $250 on newegg and the SW450 is going for $200 @ BB. It will be used for 50/50 HT and the other half for music. I like to listen to a lot of Rap and Hip/Hop. Which one will be better for my use? They seem similar besides their size...here is the break down:
PSW505
Peak Output: 460W
Continuous Output: 300W
Range: 23-160hz
SW450
Peak Output: 450W
Continuous Output: 200W
Range: 28-120hz
PSW505
Peak Output: 460W
Range: 23-160hz
SW450
Peak Output: 450W
Range: 28-120hz
Post edited by mkshul on
Klipsch.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Welcome to the Club!
I say go for the Polk!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
In this case I'd go with whatever is cheapest but you should keep in mind that lower end Klipsch subs are SLOPPY on MUSIC....they're pretty good for HT. But they're flabby and slow on tight bass. However if you listen to a lot of rap.....most of that bass is not REFINED or TIGHT bass so you may be OK there!
+1 for the PSW505. I haven't heard the Klipsch, but I do have the 505 and it blows me away. Very tight on the bass for music (even rap
) and for HT it does awesome as well. HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp. -
Where are you seeing the SW-450 @ BB for $200? It's showing everywhere as $450 for me.
It was at the store, showed it right there on the shelf. I'll have to go back and double check
