Question on HDMI pass through
djseafood
What I want to do is connect my laptop via it's HDMI output to my system so I can watch videos on my TV. My current TV has only one HDMI input and am already using that for my dish network DVR. I know that my Onkyo TX-SR506 only does HDMI passthrough so my question is this:
If I connect my laptop the the AVR and use the HDMI pass through to send the signal to the TV, can I then get the audio signal back to the AVR via the TV's audio out port? Or does the AVR only pass the video signal to the TV and audio is lost?
The way I have my DVR setup, I send the HDMI signal dirrectly to the TV via HDMI cable and then run a separte Tosslink cable from the DVR to the AVR. I guess I could test my current setup by removing the Tosslink and sending the audio back to the AVR in the method described above.
I appreciate any input.
Thanks!
AJ
Thanks!
AJ
HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
Post edited by djseafood on
You are going around the block to visit your next door neighbor.
Try this:
Make all source connections (DVR, laptop, etc.) to the AVR via HDMI. Then coonect the HDMI out of the AVR to your TV.
Switch between the sources via the AVR. This will require some setup in the AVR (assigning inputs, etc) but you should have an onscreen menu from the AVR to help.
The AVR will pass only video to the TV and handle all audio. Of course, this means your AVR must be ON in order to have audio.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I would do that in a hearbeat but I think the problem with my AVR is that it does not process the audio coming in from an HDMI source. It says this in the manual:
On the TX-SR506, audio signals received by
the HDMI IN jacks are output only by the
HDMI OUT (pass thru). HDMI sources are not
output by the speakers connected to the AV
receiver.
This is why I'm going around the block as you say
HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp. -
Wow... well. I don't even know what to say. That makes ZERO sense to me.
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Hey, it was only $119! What more can I say
I can stand to run up to three more cables than I need to for that price! HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
Let us know what you come up with...
Perhaps your TV has multiple inputs and can do the switching? Source via HDMI --->TV via toslink --->AVR?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
As you said, I would sub the DVR for the laptop and try it out. At best you will probably only get 2 channel coming back from the TV.
That's what I'm expecting, but that's okay. It will be low quality streaming Netflix or whatnot anyway so I'm okay with 2 channel.HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
I would be very surprised if you can get audio back from your tv. You will need to connect the laptop to the avr also."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
And we hit another road block:
From the user's manual for my Toshiba 30HF84
"Note: This TV is not intended for connection to and
should not be used with a personal computer."
Well there's one more kick to the nuts!HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
If your computer has HDMI it should be fine. I think you will be able to select the proper screen resolution in your display settings.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
I definitely have some testing out to do. I was going to order a few HDMI cables from Monoprice today but will hold off till I answer some of these questions.
Thanks for all the help!HT
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
2nds: DLK 1 1/2's
